Lucas Oil Transmission Additive - Ford Powerstroke Diesel Forum
post #1 of 13 Old 05-06-2013, 05:40 PM Thread Starter
Quoted: 4 Post(s)
My 200k mile 2004 Torqshift is giving me problems by rough shifting even after a well respected transmission shop in my area said it was fixed when the solenoid sensor was replaced. The mechanic said my pan was clean and my fluid looked good so I was wondering if adding the Lucas Oil additive would help me any even if my fluid was good? Havent read too many fourms on it but the guy who works at my local NAPA said it helped his car a whole lot and he hasnt had any problems since.
Any thoughts on this one?
joejack6.0 is offline
post #2 of 13 Old 05-06-2013, 07:25 PM
I don't know... but everytime I pick up a can of transmission fluid at a parts store, it states: DO NOT USE in transmissions that require Mercon SP trans fluid. I believe it's synthetic, I couldn't find mercon SP anywhere but at a dealer.
If it was my transmission... I wouldn't put anything in it but Mercon SP.
I've heard bad things when folks don't use the Mercon SP in the torqshift trans.
FWIW... I got 235k miles on my torqshift trans, with only one trans flush @ 175k miles running @ 10k lbs GVW.
04 E350 Van is offline
post #3 of 13 Old 05-06-2013, 07:28 PM
Yeah it's a Turbo Diesel
mts678's Avatar
Quoted: 12 Post(s)
Feedback Score: 12 reviews
Ford has a Trans fluid additive
Sent from AutoGuide.com App
2017 f250 platinum
Bone stock until warranty expires!
mts678 is offline
post #4 of 13 Old 05-07-2013, 02:53 AM Thread Starter
Quoted: 4 Post(s)
Where can I get it and how much does it cost?
post #5 of 13 Old 05-07-2013, 06:50 AM
DoubleDpsd's Avatar
I personally would not use a lucas additive in my trans or any additive for that matter. Never seen a 'ford additive' for a 5r. Never heard of that. I'll google it right now
2003 centennial edition f250 4x4 ccsb auto w/blackwater long block w/arp's, 4" exhaust, airaid intake, ODawg's manifold, itp's reg return, sap modified solenoid, DC power 185amp alt, motorcraft 850cca, Warn Hubs, RS 55w 6k hid's, harley headlights, bpd 58v 6 phase, bpd water pump, dieselsite coolant filter, elc coolant, php gryphon, Xcal2 w/unlimited tow, new hfcm, glowshift fuel psi gauge, icon level kit, 20" kmc hoss, 305/55 terra grapplers TOTALED
DoubleDpsd is offline
post #6 of 13 Old 05-07-2013, 06:53 AM
DoubleDpsd's Avatar
Couldn't find a trans fluid additive made by ford/motorcraft
post #7 of 13 Old 05-07-2013, 06:55 AM
ZMANN's Avatar
Quoted: 1566 Post(s)
your trans is very sensitive due to the solenoids
use Mercon LV or SP
We Miss you Ronnie
ZMANN is online now
post #8 of 13 Old 05-07-2013, 06:57 AM
ZMANN's Avatar
PS I do not believe Motorcraft has any " additive for the torque shift
your probably thinking of the friction modifier for the LS rear end ?
We Miss you Ronnie
ZMANN is online now
post #9 of 13 Old 05-07-2013, 06:59 AM
ZMANN's Avatar
best thing I think you can do for a a 5r is upgrade to an in pan filter from a 08 late -10
it will require a new pan also
We Miss you Ronnie
ZMANN is online now
post #10 of 13 Old 05-07-2013, 05:55 PM Thread Starter
Quoted: 4 Post(s)
Approximate cost? And will it make my shifting smoother?
