Need some help! P0718, P0756, P2701 - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-03-2013, 03:42 PM Thread Starter
allprodiesel's Avatar
Exclamation Need some help! P0718, P0756, P2701
Just installed new BTS trans in an 04, randomly goes into limp mode. I think it is the P0718 that is causing the problem but cant find any info other than it is a noisy TSS. I cant call Brian to ask him so need some help trying to fix this. Im sorry Im just not a tranny guy .
Thanks
Scott
03 6.0L F-350 ECLB 4WD 240k on the clock
Warren Diesel 175/75s, Regulated Return, MTW Stage II,
5in MBRP, EGR Delete, PHP Tuning and FICM Tuning,
APD Traction Bars, 35's, and groceries in the bed...
Trying to see how long the stock head bolts last...
Also have a 99 7.3 with the motor tore down, gettng some more goodies. It made 507/1130 on stock turbo and tranny
allprodiesel is offline
post #2 of 3 Old 05-09-2013, 05:49 AM
Replace the TSS first, the next is that the p2701 is an OD clutch failure code, looks like you might have a sticking solenoid or your OD drum is burnt up.
Owner/Founder of Georgia Diesel Power.
Current Sponsors: QuickTricks Automotive, Ray Paul Powdercoating, Ace Transmission, SoCalTrucks.com
Current Member Count: 16
TheRobenator is offline
post #3 of 3 Old 05-10-2013, 02:23 PM Thread Starter
Its a tuning issue. The 03-04 trannys are different then the 05 up and needed a reflash.
