Thud when coming to stop or leaving in 1st gear - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-15-2013, 06:07 PM Thread Starter
Hi there,
Got a 2005 F350 6.0 with the auto tranny in it, when I come to a stop at a set of lights etc you can really hear the trans go back down into first get like a thud/feel this also or when you pull away you can sometimes hear this also. It shifts fine does not slip etc WOT no problem and shifts great. It's just whe I come to a stop or go to move off again I get a thud.
Any ideas what this could be? I'm thinking it could be a prop issue or something along those lines but I have had a look and can't see anything that would cause any reason for concern. I flushed the rear end fluid and everything looked ok in there, I also put a new filter on the trans and flushed the fluid with new ford fluid. The level is perfect and there is no leaks.
Cheers Phil
Phi1 is offline
post #2 of 4 Old 04-17-2013, 03:44 AM
Joeshu1000's Avatar
I would pull the drive line and remove the rubber boot and re-grease the splines. I would also check the carrier bearing and make sure the rubber around the bearing isn't coming apart. I had a Ranger that had the greased splines and it was popping when you'd stop and start so I pulled it out and re-greased them and the popping went away. I've had my drive line out in my truck and it's a heavy SOB.. Hopefully someone else will have some ideas.
Joe
2006 F350 XLT CrewCab 4X4
325/65R18
EGR Delete
Zoodad Mod
High-Idle Mod
Sinister Coolant Filter
ARP Head Studs W/ OEM Gaskets (Installed myself)
Upgraded Fuel Spring
Updated STC Fitting
Updated Oil Cooler Screen
Updated Dummy Plugs/Standpipes
6.4L Banjo Bolts
PHP Ficm Tuner
1/4 Mile 14.2 @ 93MPH
SCT Custom Tunes: MKM, Looney, SRL, SRLXX, Wildman and SPD w/ Early Lock up
Joeshu1000 is offline
post #3 of 4 Old 04-30-2013, 07:24 PM
Joe is right on when he says; "I would pull the drive line and remove the rubber boot and re-grease the splines."
I'm told that Ford has a bulletin that suggests the same fix.
My son developed a better fix.
He grinds a ring around the spline (not necessary but it allows the lube to distribute) and installs zerks on the shaft so it can be periodically, easily lubed.
2006, F-350, 6.0, 4x4, Lariat, crew cab, long bed
MagnaFlow 4" turbo back exhaust system
DC Power Engineering 190 amp alternator
Ranch Hand Legend grill guard
Firestone Ride-Rite air bags
HID Bi-Xenon headlights
HFCM water drain plug
Accufab intake elbow
Bilstein 5100 shocks
Ctek batteries tender
DFuser coolant filter
Blue Spring mod
ScanGauge II
Up-idle mod
Zoodad
ARCHOIL (AR9100, AR6200) & PRI-D & PRI-G Dealer
SnowGoose is offline
post #4 of 4 Old 05-03-2013, 03:56 AM Thread Starter
I removed it and lubed it and all clunking has now gone away!!
Phi1 is offline
