Is my trans done - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-07-2013, 12:04 PM Thread Starter
josh_2563's Avatar
Is my trans done
2004 f250 4x4 6.0 161,000 miles auto trans
Drive the truck last night every thing was fine. Go out today and backed out of the drive way. Put it in drive and nothing. Give it gas and feels like and it feels like its in a high gear. It will drive but struggles like its in 5th gear. Fluid level is good. No codes
josh_2563 is offline
post #2 of 5 Old 04-07-2013, 05:40 PM
LiftedStroker05's Avatar
torque converter possibly? im not very good with trannys in these yet but i had a older ranger once where i had a simular problem so i replaced the torque converter and the problem was cured. like i said, im no pro with these trannys but thats what i have experienced. Best of luck to you!
'05 f250 6.0 stroker
ARP studs, Barder fmws468, warren 225/75s,EGR delete, stage 3 hdp trans
4" MBRP to 7" tip,sinister collany system
sct tuned w/ SRL++ xtreme tune
20x12 riots with 420s
Air Dog fp150 w/ 1/2" fuel lines,blue spring mod,
zoodad mod,traction bars
LiftedStroker05 is offline
post #3 of 5 Old 04-12-2013, 03:34 PM
Quoted: 4 Post(s)
Well where do I begin...
Every time I put it in D there is a 1-2 second hesitation followed by a thud, When it shifts it always struggles, I upshift occasionally, Rough Shifting, and how I know there is a major issue?
My tow haul light is flashing.
What could be causing all of this.
joejack6.0 is offline
post #4 of 5 Old 04-12-2013, 04:06 PM
When was the last time your filters were changed? As in both of them? It could be as simple as a sticky solenoid. Given the you reported the fluid is good, I'd say this may be it. I recommend a hot fluid flush and new filters. If it's not hot, then the trans thermostat won't be open.
Sent from my LG-VS700 using AutoGuide.Com Free App
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #5 of 5 Old 04-12-2013, 04:34 PM
Quoted: 4 Post(s)
I don't know when they were last changed to be honest. I was talking to a guy at a transmission shop and I described my problem and he said it sounded serious due to the thud whenever I put it in gear. Also my gas mileage has decreased significantly over the past week because I was running a higher RPM than normal and my truck was acting as if it were under a load. I have a lag in power now and my gas mileage is decreased.
