6.0 Tannie not responding? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-04-2013, 04:57 PM Thread Starter
InternationalHarvester7.3's Avatar
Alright I have a 2003 6.0 4x4 with the auto tannie, the truck has 155,xxx miles and has had the fluid and filter changed in the past 400 miles and has never slipped or missed one time but I was driving down the road going about 65 and the O/D light started flashing and it shifted out of O/D so I pulled over and shut the truck off and started it and had no problem, until later that day, I was driving back and the truck did the same thing and then slipped and completely quit. I can shut the truck off for a little bit and start it back up and move a few feet and it will quit again and it acts like its in neutral.. does anyone know what caused this or can anyone help?
7.3 and my 6.0.
6.0, 2003.
EGR Delete
APR Headstuds
SCT Tuner
Upgraded oil cooler
4'' Turbo back
FASS Fuel system
7.3, 1996.
Bone stock with
Motor and trannie swap with under 150,000 miles.
Red and black
InternationalHarvester7.3 is offline
post #2 of 5 Old 04-04-2013, 05:04 PM
DoubleDpsd's Avatar
Check fluid level but other than that it sounds like it's toast
2003 centennial edition f250 4x4 ccsb auto w/blackwater long block w/arp's, 4" exhaust, airaid intake, ODawg's manifold, itp's reg return, sap modified solenoid, DC power 185amp alt, motorcraft 850cca, Warn Hubs, RS 55w 6k hid's, harley headlights, bpd 58v 6 phase, bpd water pump, dieselsite coolant filter, elc coolant, php gryphon, Xcal2 w/unlimited tow, new hfcm, glowshift fuel psi gauge, icon level kit, 20" kmc hoss, 305/55 terra grapplers TOTALED
DoubleDpsd is offline
post #3 of 5 Old 04-04-2013, 05:07 PM Thread Starter
Fluid is all good and new.. but is that common for a trannie to just go out with out slipping at all? It showed no sign of being weak at all at pulling, climbing, or driving.. I have always had 5 speeds and never liked autos so this is new to me and just continues my hate for them.
7.3 and my 6.0.
6.0, 2003.
EGR Delete
APR Headstuds
SCT Tuner
Upgraded oil cooler
4'' Turbo back
FASS Fuel system
7.3, 1996.
Bone stock with
Red and black
post #4 of 5 Old 04-04-2013, 05:20 PM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
its cause you flushed it. more than likely tons of crap came loose and clogged the filter and or you killed some solenoids. pull some codes and let us know. i dont think the whole truck is fried yet but your truck definitely has no pressure to shift gears or hold it in gear. when most places do a trans flush they never change the filter.
07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Smoked Lights, No Limit S2 Intake, 20% Tint, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, Toyo MT's, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, super bright leds 6500K heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
Thanks to bigblack for selling me his truck
MyTractorsSexy is offline
post #5 of 5 Old 04-06-2013, 12:36 AM
turbotibbo's Avatar
Disconnect the batteries and try to do the relearn
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
