Stuck filter canister - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-01-2013, 06:31 PM Thread Starter
frdbronco8's Avatar
I cant seem to get the canister holding the external trans filter off. I tried a breaker bar but didnt go too crazy with it for fear of the whole assembly twisting off. I just picked up a air impact gun and even it didnt work. Anyone have any tricks?
frdbronco8 is offline
post #2 of 5 Old 04-01-2013, 06:51 PM Thread Starter
frdbronco8's Avatar
Ok I am impatient and just tried a longer breaker bar, the bracket that holds the whole assembly started to bend as I feared..... Also a small piece of the bolt shaped end broke off but most of it is still there...
post #3 of 5 Old 04-01-2013, 08:14 PM Thread Starter
frdbronco8's Avatar
So I tried heating it and ran the impact on it some more and eventually broke off the nut shaped portion on the bottom..... So now I am going to have to replace the canister no matter what. It appeared to be aluminum or maybe magnesium. I am now wondering if I squeezed it with some kind of press if it would crack and break and fall off......
post #4 of 5 Old 04-01-2013, 08:16 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Holly hell u gotta wonder if it has ever been turned....well I guess now you got a excuse for a better aftermarket set up.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #5 of 5 Old 04-02-2013, 02:01 AM
A impact should have taken it off.. I bet it hasnt been changed in a long long time if ever, Or the last owner just put it on way to tight after changing the filter. It looks simple to replace though so thats kinda nice.
05 CC SB 6.0 FX4
SCT w/ SPD
Gryphon Tuned
ARPs
New UCF Heads ported & Oringed
Blue fuel spring
sinister coolant filter
Egr Delete
5" DiamondEye TBE
BFG ATs 35s
ELC Cat-1
Scangauge
EGT/ fuel/ oil psi gauges
Bilsteins Shocks
08+ Aluminum Axle Cover
08+ Trans Pan W/Filter
MTW stage 2 DD solenoid
24+ years Ford Employee
SharkDiver is offline
