Jerking transmission - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-17-2013, 06:27 AM Thread Starter
Hey I have an 06 f350 king ranch with the 6.0 engine. When the engine and transmission are cold the transmission doesn't want to shift and when you get around 60-65 mph in overdrive the transmission starts to jerk and shake the whole truck. If anyone on here had expericned this and knows how to fix it please let me know. Thank you.
Isaacguettler is offline
post #2 of 8 Old 03-17-2013, 06:34 AM
jesilvas's Avatar
Quoted: 2 Post(s)
I'd do some searching, cause I've come across this fairly often in my "studies."
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 8 Old 03-17-2013, 07:47 AM Thread Starter
I forgot to say that once it warns up it quits.
post #4 of 8 Old 03-17-2013, 08:00 AM
twoicebergs's Avatar
Quoted: 46 Post(s)
Firstly, welcome! Secondly, the search function works really well. Read, read and read again!
Without more info, I would say your shift issue may be a function of low power or - need more info - but, primarily it sounds more like an injector problem.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #5 of 8 Old 03-19-2013, 04:43 PM
bigbear75's Avatar
isaac...i have a 05 6.0L w/ 56k and was having the EXACT same problem. I took it in to three aftermarket mechanics and they spend a couple hundred dollars of my money each place and came up with nothing. I finally said F'it and took it the dealership and one week and $7,000 later....the egr valve was broke off and sitting inside the manifold in pieces and all the egr parts and pieces and oil cooler were clogged and defunked, a couple head bolts were cracked, intake seals were leaking and two injectors had failed. I had installed the bulletproof EGR complete package, ARP studs, ALL new injectors, Snap connect fitting upgraded and a partridge in a pear tree. I'm picking her back up tonight.....
bigbear75 is offline
post #6 of 8 Old 03-25-2013, 05:34 PM
psdparts's Avatar
I would bet you have an injector missing/dropping out when its cold, try some rev-x and/or fuel treatment?
psdparts
psdparts is offline
post #7 of 8 Old 05-03-2013, 05:50 AM
Any one heard of an issue with a wirring harness to the shift Siloniods in the pan of the trans? Have had this issue for a year now with no codes and yesterday pulled a favor from a good friend who restores classic muscle and he had a trans guy give me a call. Said its a common issue somtimes miss - somtimes perposely - diagnosed as the shift siloniod. Ive ran every test there is to run on the engine in my 06 that a Pegisys scan tool will run and when warm the truck runs great. Not being able to diag this shutter when cold is getting under skin as I hate replacing whats not broke. Read many but wonder have i just missed the thread with the answer?
KLT1969 is offline
post #8 of 8 Old 05-24-2013, 07:20 PM
turbotibbo's Avatar
I agree with this . you have stiction look it up
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
