Leaking Transmission Fluid - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-15-2013, 10:27 AM Thread Starter
I have a 2004 F350 6.0 Torqueshift 4X4 Crewcab Dually. It is leaking transmission fluid between the bellhousing and the engine. It seems to be ok when recently driven but when the truck sits for a while then the leak starts again. Am going to pull the transmission needed to know what to look for?
I attached a picture to show where the fluid is coming from. It also comes out around the starter. Any help would be greatly appreciated.
Thanks,
Jwilson5682 is offline
post #2 of 4 Old 03-15-2013, 12:27 PM
twoicebergs's Avatar
Quoted: 42 Post(s)
Is it ELC (red coolant) or trans fluid?
Weepage out of the front seal is possible, but if you don't get anything more than a few drops when sitting for a long time and it goes away when regularly driven, it may not be worth fixing. How long does it sit before this typically happens?
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #3 of 4 Old 03-15-2013, 04:59 PM Thread Starter
Thought is was transmission fluid but it tasted sweet. Looks like it is ELC coolant. Where could it be leaking from on the back of the engine by the starter and bell housing? Normally starts leaking after sitting for several hours.
Thanks,
post #4 of 4 Old 06-16-2014, 01:44 PM
Onefast96svt's Avatar
Thanks,
Am wondering the same thing. I just had studs gaskets and y pipe replaced. It's been about a month or so and now I have a red spot. Not sure if it's trans or coolant but the mechanic said he believed they used green coolant. I just found it 2 days ago and haven't had time to test it. I think it's the trans but I'm hoping it's coolant so they will fix it under warranty.
03 Excursion EB 4X4 6.0L Mineral Gray Metallic,20" machined/black Rockstars 33x12.50, 4" lift,Powerstop slotted and drilled rotors,Rancho adjustable shocks,Studs, looney tune wild,CCV MOD, Red Head Steering Box, EGR delete,6.4 banjo,XDP Coolant filter,4" MBPR straight pipe,280amp Alt,Amsoil oil bypass,Go Industries Bull Bar,6000k HIDs,ScanGaugeII
96 Cobra, way too much to list!
Onefast96svt is offline
