Transmission Flush or Change Fluid? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 03-15-2013, 07:45 AM Thread Starter
Quoted: 4 Post(s)
My transmission is due for more fluid (it will occasionally upshift and shifting is rough) is and I was wondering how I should get it done, shall I have it flushed or should I just change the fluid? I have heard that flushing it causes the filter to get clogged and causes damage. Is that true?
joejack6.0 is offline
post #2 of 11 Old 03-15-2013, 12:04 PM Thread Starter
Quoted: 4 Post(s)
Also I just called a local transmission shop and they said the fluid has nothing to do with the upshift and rough shifting! I've heard from many people that the way to fix it is new fluid. Who is right? The shop or the people I talk to?
post #3 of 11 Old 03-27-2013, 01:32 AM
I would take it to ford and have them do a heated flush.. It costs about $200 in my area and was worth it..
05 CC SB 6.0 FX4
SCT w/ SPD
Gryphon Tuned
ARPs
New UCF Heads ported & Oringed
Blue fuel spring
sinister coolant filter
Egr Delete
5" DiamondEye TBE
BFG ATs 35s
ELC Cat-1
Scangauge
EGT/ fuel/ oil psi gauges
Bilsteins Shocks
08+ Aluminum Axle Cover
08+ Trans Pan W/Filter
MTW stage 2 DD solenoid
24+ years Ford Employee
SharkDiver is offline
post #4 of 11 Old 03-27-2013, 04:39 AM Thread Starter
Quoted: 4 Post(s)
Ok and will that fix slippage and rough shifting?
post #5 of 11 Old 03-27-2013, 05:25 AM
Snake's Avatar
Quoted: 46 Post(s)
It might, and it might not. Depends on if your trans is healthy.
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
post #6 of 11 Old 03-27-2013, 06:50 AM
Its a good place to start..Thats what I would do.
05 CC SB 6.0 FX4
SCT w/ SPD
Gryphon Tuned
ARPs
Blue fuel spring
Egr Delete
5" DiamondEye TBE
BFG ATs 35s
ELC Cat-1
Scangauge
Bilsteins Shocks
post #7 of 11 Old 03-27-2013, 07:03 AM
drstephennix's Avatar
Quoted: 2 Post(s)
Send a message via Yahoo to drstephennix
Do the flush and then change the in line trans filter. Passenger side by front bumper. It probably needs to be done anyways as a general maintenance procedure.
2011 F-350 CCSB KR 4x4
35" Hancook AT's
AFE CAI
6.7 Scorpion
197k miles
Back in the diesel game!
In the words of David Crockett, "You may all go to hell. I will go to Texas!" spoken in the halls of congress; circa 1830's
drstephennix is offline
post #8 of 11 Old 03-27-2013, 11:06 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Do what BTS recommends..drop the pan, new filter and refill 8qts..every 30k.
CT Performance, Inc. is offline
post #9 of 11 Old 03-31-2013, 05:03 PM
asian195's Avatar
Quoted: 2 Post(s)
I was wondering if you can clarify on what your trans is doing? Mine is acting up also. While driving, it will upshift for a half second then back down. Kinda like its slipping, but with a positive engagement. I changed the filters and replaced the 8qts it drained, today. Only had time to drive a few minutes, but it still did it. Time will tell I guess.
2003 F-350 6.0L.
Leveling kit
35/12.50-20 Federal Couragia M/T
20x10 black Fuel Hostage wheels
4"-5" exhaust no cat
Airaid intake
SCT tuner-awaiting custom tune
Edge Insight CTS
Blue spring
6.4 Banjo bolts
Zoodad mod
EGR Delete
ARP Head Studs
To Do/Wish list:
FICM tune
BPD Oil Cooler/Filter
Fog light mod
Harpoon mod
Injectors 155cc
asian195 is offline
post #10 of 11 Old 04-04-2013, 10:40 AM Thread Starter
Quoted: 4 Post(s)
Thank you everyone!
