Codes/hot/now drives in Neutral - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-10-2013, 09:57 AM Thread Starter
JAVA JOE's Avatar
So I install ID custom street tune from the tow tune and I'm driving it and it just goes into limp mode with the tow flashing, I go back to stock and it drives but now my tranny gauge climbs fast to really hot so im not driving it, no reverse, in neutral it will drive, codes are P0730 coast solenoid, P2701 overdrive pressure solenoid, P2703 Trans friction element D apply friction range. Worst part was a had a 20k dollar check in my hand as the guy was test driving my truck to buy it. Pretty embarrassing. Trans fluid seems full and clear pink. Any ideas guys? It's an 03 engine
2004 LARIAT F250 4X4 CC LONG BED
8" LIFT W/ 37'S ON WELD EVO'S AND REAR AIRBAGS
AIRAID INTAKE, 4" STRAIGHT PIPED W 5" TIP
MAG-HYTEK TRANS AND DIFF. PANS
PROCOMP PILLAR GAUGES
SCT X3 RUNNING I.D EXTREME RACE
2000 WATT INFINITY AMPS AND SYSTEM
TT MEMBER
JAVA JOE is offline
post #2 of 2 Old 06-19-2014, 07:44 PM
jakewis93's Avatar
I know this is an old thread but I was wondering if you ever found out what the problem was? My truck is doing the same thing
CCLB Dually, 4 inch lift, 35s. Studded, Deleted, 4" Turbo Back Exhaust, SPD, PHP Hercules, Wicked Wheel 2.
jakewis93 is offline
