06 Delayed reverse and 1st engagement? - Ford Powerstroke Diesel Forum
Old 03-03-2013, 04:40 AM
My 06 6.0 has developed a lazy delayed engagement of reverse and 1st gear. Ususally after it has set all night or for a extended period. Is there a certain solonid in the trans that can be acting up that can be repalced?I did just replace both trans filters and do a fluid swap/flush and everything looked normal in the pan and filters. Please help me out. This issue is very annoying and Id like to fix it asap.
Thanks....Jimmy
Old 03-03-2013, 04:43 AM
Sounds to me like low fluid level. Warm it up and re check it.
Old 03-03-2013, 04:58 AM
Re: 06 Delayed reverse and 1st engagement?
Start saving $
Old 03-03-2013, 06:07 AM
Fluid level is fine. Theres threads about changing solnoids and help/fixing the problem but havent exactly pin pointed the actual one people are changing.
Old 03-03-2013, 06:09 AM
Be gentle with it and start saving for which ever built tranny you want. This is exactly what mine did before I got a BTS trans.
Sent from AutoGuide.com App
Old 03-03-2013, 08:32 AM
Feedback Score: 5 reviews
If you find out you need a BTS...we can get you one quick.
Old 03-03-2013, 11:13 AM
sounds like it could potentially be a solenoid problem. a sticking PC-A (line pressure) solenoid will cause problems like this. the low reverse solenoid could also be an issue. its best to follow fords pinpoint tests.
Old 03-03-2013, 12:07 PM
If one solenoid is on its way out the rest are not far behind
Old 03-04-2013, 07:46 AM
Mines doing the same thing. Started this past Thursday. But it also started missing gears and staying in 3rd at 60 mph until its warmed up.
Old 03-13-2013, 07:28 AM
Replace solenoids for that gear, if problem persists, your clutch packs are probably shot.
