HELP! 2nd tranny dead! - Ford Powerstroke Diesel Forum
post #1 of 13 Old 02-22-2013, 10:56 AM Thread Starter
I've owned my '03 6.0 since since 08/07. 12/08 at around 55K miles the tranny went bad, would seemingly not go into 4th gear, then slam in, possibly downshift, pull again, then same scenario all over. If I would drive hard enough to keep it in 2nd or third, then let off the throttle to let it up shift to 5th it would do fine. I had it rebuilt by a local national chain transmission shop,( if I remember right they said the main drive clutches were shot,) and all was well until now. They also said that a solenoid had likely failed causing it to hang up in 2 gears which caused the clutches to burn up. 90,000 miles later it is doing the same thing. I find it unacceptable to put a tranny in every 100k miles or less. The truck is essentially a cowboy cadillac,living in the city. It pulls my 3500lb boat a dozen or so times a year. It has a banks sixgun tuner, banks intake, and oversized exhaust. tires are 285/75-16. I had Ford service the tranny at 75,000 miles. I also noticed that this time the tow position light on the shift lever started flashing. My question is, is this to be expected from this tranny? Or would I be better served by a hi performance tranny from someone such as BTS? Since my probem is in the upper range of gears, would it be good to put in the GoGo Diesel Modified Direct Clutch Solenoid Ford Powerstroke 6.0L. Has anyone ever tried it. I love my truck, but right now, I'm considering fixing, selling it, and buying an F150. Right now I'm very dismayed, please help. I wish I would have held out for the stick.
walter.dreyer is offline
post #2 of 13 Old 02-22-2013, 11:18 AM
DoubleDpsd's Avatar
Re: HELP! 2nd tranny dead!
Provide more info on your banks tuner and how you use it.
2003 centennial edition f250 4x4 ccsb auto w/blackwater long block w/arp's, 4" exhaust, airaid intake, ODawg's manifold, itp's reg return, sap modified solenoid, DC power 185amp alt, motorcraft 850cca, Warn Hubs, RS 55w 6k hid's, harley headlights, bpd 58v 6 phase, bpd water pump, dieselsite coolant filter, elc coolant, php gryphon, Xcal2 w/unlimited tow, new hfcm, glowshift fuel psi gauge, icon level kit, 20" kmc hoss, 305/55 terra grapplers TOTALED
DoubleDpsd is offline
post #3 of 13 Old 02-22-2013, 01:31 PM Thread Starter
always on 6, it gets better mileage there, otherwise normal daily driving, with the occasional stomp for fun. 30 miles to work and back. Mostly highway.
post #4 of 13 Old 02-22-2013, 07:04 PM
KingPowerstroke34's Avatar
What size tires?
Sent from AutoGuide.com App
KingPowerstroke34 is offline
post #5 of 13 Old 02-22-2013, 07:23 PM
DoubleDpsd's Avatar
Since you've owned it how long have you run the banks tuner on level 6?
post #6 of 13 Old 02-22-2013, 07:31 PM
05_PSD_Erik's Avatar
There's your problem. Banks tuning is notorious for grenading transmissions....
Best bet would be get this one fixed, and if you are going to run tuning, get an SCT and custom tuning. Banks tuning doesn't do anything to the TCM (trans cotrol computer) whereas the SCT devices actually tune the Engine computer and the transmission computer adjusting the transmissions "thinking" for the increased engine output, leading to a much better transmission life. While this doesn;t make the transmission bullet proof, it definitely helps with the shift points and overal longevity of the transmission. With an SCT and custom tuning, you'll have more power than with the banks and your truck will live a much better life, especially the transmission.
The 5R110 transmission found in these trucks is one of the strongest autos out there for, in my opinion. There are several people, myself included when I owned my 6.0, that ran custom tuning via an SCT device for many many trouble free miles. I still run SCT custom tuning on my 6.4 I drove my truck daily on 35s and while I didn't abuse the truck, I did enjoy the power on occasion and towed with it fairly often. I had zero transmission issues out of my truck.
2009 Subaru WRX Premium
Type RS BOV
CAI
Muffler Delete
Had to park it with some real diesel muscle....
05_PSD_Erik is offline
post #7 of 13 Old 02-22-2013, 08:17 PM Thread Starter
That's interesting. This is the first I've heard of the banks tuner being hard on the tranny. They claim that the tuner increases line pressure to help clamping force, and supposedly has built in safety features to prevent damage to your truck. Please don't get me wrong, I'm not opposed to getting rid of the banks unit. I'd like to hear from others as well. Still would it be worth getting the hi-po tranny, or just get mine rebuilt again. difference is going to be about $3000 !
post #8 of 13 Old 02-22-2013, 08:41 PM
PGreenSVT's Avatar
Feedback Score: 3 reviews
BTS makes a great trans. You would probably be just fine with something like a PATC level 3 for about half the cost of the BTS.
Got questions about your 6.0?
Still runninng Ford Gold Coolant?
PGreenSVT is offline
post #9 of 13 Old 02-22-2013, 09:41 PM
sprksonu's Avatar
yep get rid of that banks and go with sct.
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
post #10 of 13 Old 02-23-2013, 08:53 AM Thread Starter
I did some research and I think I understand it now. The problem is the adaptive portion of the stock programming. I may train my tranny to the increased power of the Banks, but after driving it awhile normally, it reverts back to stock settings. Then when I punch it, the tranny isn't ready for the increased power levels. Apparently the SCT with a custom tune will over ride the adaptive portion of the program, and keep the tranny tuned for the increased power levels (Firmer shifts) at all times.
