5r110 Stuck In 3rd - Ford Powerstroke Diesel Forum
post #1 of 14 Old 02-09-2013, 10:00 AM Thread Starter
5r110 Stuck In 3rd
I have an 03 f250 with the 6.0 diesel engine and 5r110 trans. I was driving it home the other night and it wouldn't shift out of 3rd gear.
I checked the fluid was a pint low so I added sp into it. Took it for a drive and everything seemed fine. Then yesterday I was driving it around and everything seemed fine. Then all of a sudden again it wouldn't shift out of 3rd gear. First and second seem to shift fine its just third. So I go to move it and reverse also feels like I have the e brake on. Any ideas what this could all be?
Thanks for your input.
Cmmoreno00 is offline
post #2 of 14 Old 02-09-2013, 08:46 PM
FORDHARLEYFAN's Avatar
mine is doing almost the same thing......i would like to know myself what is going on.
FORDHARLEYFAN is offline
post #3 of 14 Old 02-10-2013, 08:33 AM
sounds like a failing intermediate clutch solenoid or a bad direct drive solenoid. it really needs to be diagnosed with a ford scan tool and a line pressure gauge. i wouldnt drive it anymore
2006 F350 XLT Sport SCSB 4x4 6.0L - ARP Studs, Blocked EGR Cooler, Diesel Site Coolant Filter Kit, PHP FICM Tuning, Innovative Xtreme Tuning, Dual Fuel Pumps, Elite 1??s, Garrett Powermax, 6.4L Trans -
12.70 @ 104.87 Elite 1??s w/ Powermax Turbo
13.23 @ 100.89 Stock Injectors w/ Powermax Turbo
13.35 @ 100 Stock Injectors w/ 03 Turbo 430rwhp
SICKS-O is offline
post #4 of 14 Old 02-10-2013, 09:01 AM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Feedback Score: 4 reviews
I'd lean towards a failed direct clutch. The manual valve is what controls fluid flow to the direct clutch in reverse so that takes the solenoid out of the equation.
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #5 of 14 Old 02-10-2013, 09:58 AM
JD_MILLS's Avatar
Re: 5r110 Stuck In 3rd
My 6.0 did something very similar turned out to be a toast direct clutch.
2008 f-250 LARIAT, SCT LIVEWIRE, S&B CAI, 8" MBRP STACK
JD_MILLS is offline
post #6 of 14 Old 02-10-2013, 08:41 PM Thread Starter
Thanks for all the advice. Ill be taking it to the ford dealership so they can tell me what it is.
I did forget to mention that it only happens when I've been driving it for about 30-45 minutes. I guess that's a key piece of info I forgot to let you guys know.
post #7 of 14 Old 02-10-2013, 08:45 PM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
change the shift solenoid with the gogo solenoid.
2006 Ford F250 CCSB FX4 6.0
Sold
1997 F350 CCLB 2WD 7.3
1999 F350 CCLB 4WD 7.3
2003 F350 CCLB FX4 6.0
LSP Chapter Director
LSP Group Threads
Jarrod B is offline
post #8 of 14 Old 02-10-2013, 09:03 PM
JD_MILLS's Avatar
You may be lucky and it not be the clutch then. Mine would do it as soon as it shifted to third. No matter what temp it was or how long I had been driving.
Sent from my SCH-I500 using AutoGuide.Com Free App
JD_MILLS is offline
post #9 of 14 Old 02-10-2013, 09:04 PM Thread Starter
Where can I get one of those solenoids at? Im new to the diesel and ford worlds.
post #10 of 14 Old 02-10-2013, 09:07 PM
ZMANN's Avatar
Quoted: 1464 Post(s)
here Go Go Diesel
but I am not saying this is the issue
these trans are clean/proper fluid sensitive
the GOGO is a modified OEM
if time is an issue and your just going to try it without diagnostics go to the dealer and hit me back I can send u some PDF's to help u change it
also the pan gasket is reusable
We Miss you Ronnie
ZMANN is offline
