Tow/Haul started flashing today. Noticed temp gauge in the red and CTS shows temp all over the place. I know it's not running hot because I have a mechanical gauge as well. It's setting a P0712 code for the TFT sensor. I've read that it's a pretty common issue. Anyone have the Ford part number for the sensor?
That is the part I used on mine.
I had replaced the sensor bout 2 months ago but it started acting up again last week. I installed a new wire harness last night and it works fine now.
Harness part is 4C3Z-7G276-AA if you need it.
Not as easy as just swapping the sensor but doable....
Listen guys i have 03 6.0 f350 an i changed the trans temp sensor and it worked for a week an started back flashing the tow haul light again. Besides its holding the gears longer now.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
