switch to AMS oil and now higher temps? - Ford Powerstroke Diesel Forum
Old 01-28-2013, 05:08 PM
Chapter Director
i was curious if anyone else notice a raise in trans temps after switch to AMS oil? i'm not seeing a huge increase but still higher than before. i use to run around 140-150 but now i'm running 155-160
Old 02-05-2013, 05:44 AM
The transmission is alright between 140 and 160, anything over, something is going wrong.
Also, there is no reason to use any "Special" transmission fluids.
The only transmission fluid you need to run is Dex/Merc, the normal transmission fluid and you can't go wrong.
Old 02-05-2013, 12:34 PM
Chapter Director
Might want to look into trams fluids for these newer trucks. The 5r110 trans takes mercon SP
