torque converter duty cycle - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-21-2013, 08:48 PM Thread Starter
licenced2burn's Avatar
My trans has been acting up some so i was on a small road trip aboit 160 miles and i set my edge cts to read the torque converter duty cycle and it stayed at 0% no matter what i did. 0-60 runs, cruizing 80, slowing down, i even tried everything in tow haul and it still never changed. Idk what its supposed to read but i figured at cruizing speeds it should be locked 100% right? My truck was also running about 2100-2200rpms at about 75 with 3.73 gears and 325/60/18 tires. If someone knows more about the how the torque converter works and what it should be reading it would be greatly appreciated. The trucks going to the tranny shop this week anyways because my "built tranny" is also getting a bad 3-5 shift flare it didnt have for the first 15k after it was installed and its still under warrantee.
Tony
2005 F250 crew cab lariat,
4" lift 325/65/18 tires, head studs, built trans, egr delete, powermax turbo, 58v ficm from swamps with mild flash, 4" straight pipe, sct with innovative xtreme street and race tune's, blue spring upgrade
Stage 3, 190/100 injectors, and full fuel system on the way.
licenced2burn is offline
post #2 of 6 Old 01-22-2013, 02:32 PM Thread Starter
Does anyone know what the torque converter should read? I might be wrong but im assuming it should read 100% when it locks in OD. And i have read it locks in with certain gears threw the whole shift patern to essentially make more "gears". Any help would be appreciated or if someone could see what their truck reads for comparison
Tony
post #3 of 6 Old 01-28-2013, 06:00 PM
Chapter Director
psd_va's Avatar
i have been getting my tune revised and its been doing some weird things and i had selected the tcc duty cylce to see what it was doing an i also noticed it always read 0% no matter what i did. so your not the only one but i'm curious if this is a normal find for these trucks for whatever reason maybe some strategy conflicts or something.
03 F350 6.0 SRW 4X4 lariat
481hp 832tq
8" super lift 385/70r16 Toyo MT's
FatBoy traction bars
Durastroke stg1
intake
MBRP 5" straight pipe
Custom tuned by Vivian "Looney Wild Track"
Edge Insight CTS
Zoodad mod
high idle mod
6.4 banjo bolts
Updated fuel pressure regulator (Blue spring mod)
EGR cooler delete
6K 55w HID's
6k 35w fog HID's
B&W turnover ball
psd_va is offline
post #4 of 6 Old 01-29-2013, 03:37 PM
Ranger5.0l's Avatar
mine reads 0% also running vivians looney tune it doesnt seem to pull very hard like i think it should also dont see boost numbers higher than 24psi. milage is also down so i really think something is up with my tune or the converter isnt working right. Id like to hear if anyones duty cycle moves off of 0%
Ranger5.0l is offline
post #5 of 6 Old 01-30-2013, 05:08 AM
I don't think the edge's showing 0% is a result of any of the tunes that you guys are running because I've had the same result whenever I've set my edge to the TCC cycle and I'm running stock. Either we're all missing something or there's something about that feature that's not working properly. Somebody on here will have some insight into this I'm sure.
f250xltsuperd is offline
post #6 of 6 Old 01-30-2013, 04:29 PM
jwsland's Avatar
I don't THINK Vivians tunes have lockup unless specifically asked for. My fully built trans also has a flare from 3-5 while running the Looney tune.
06 F.350 Lariat. Daily tower.
Suncoast Trans, MTW Stage 2, Warren 175/75's
Tuned by Tony Wildman- 515rwhp/973rwtq
06 F.550 4WD 12ft Rugby Landscape Body
97 F.350 Reg Cab 7.3 New Trans w/ upg. converter, no cat, AFE intake.
jwsland is offline
