Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Trannie problems
Old 11-16-2007, 09:03 AM
Drysuit John Drysuit John is offline
Send a message via MSN to Drysuit John
Will turning OFF Electronic Overdrive ....
to slow down, like an engine brake, hurt trannie ? This is under no load, 110 k to 30 k from hyway over turn out ramps. Truck is a 04 E 350 Extended 6.0 L PSD
Old 11-16-2007, 12:40 PM
Fordinator Fordinator is offline
I do the same thing all the time. From what I have heard putting it into tow/haul only increases the pressure and changes the shift points. The only thing that might ware out sooner is the lockup clutch in the TC. When it down-shifts the TC cluch is engaged to positively lock the engine to the transmission.
Old 11-16-2007, 12:45 PM
Patrick Patrick is offline
We actually tune the SCT Xcal2, Xcal3, and Livewire to use the 6.0 turbo as an engine brake. You will be fine.
Old 11-16-2007, 08:49 PM
Thanks for the info. Drive safe there's weird 1's out there !
Old 11-17-2007, 09:00 AM
Dave Dave is online now
Obama sucks
You should be fine doing that FYI the tow haul button for the torqshift will not actually turn off overdrive.
