Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Trannie problems
Old 11-09-2007, 05:05 PM
flippedoverford flippedoverford is offline
Tranny trouble-Bullydog
Ok first thing,I am not looking for opinions.I am looking for solutions.I have been a member long enough to know how it works here.So please,just try to help a guy out and keep the negative opinions to yourself.
Now,I have a 2004 F250.It is an automatic.It has 47,000 miles on it.I have an aftermarket exhaust, 4 inch,a Volant intake,and a Power Pup programer with outlook.I have put on about 5000 miles,most of them with the chip.I usually run at 50 percent,with the smooth aggresive shift.The other day I was towing a goosneck and thought that the tranny had slipped.I continued to drive it and It became consistant when shifting(without the trailer).It would slip,then slam the gear then slip again.I since have unloaded the program completly and it shifts great.I called Bullydog 3 times today and got 3 different guys,none of which had anything to say I couldn't figure out myself,such as:"you know when you put more torque to the transmission it is harder on it than normal".I realize this,but I am not pounding on this thing all the time.If my transmission is bad so be it,I will put a new one in.I just can't believe that it is fine without it and as soon as I add more horsepower to it it slips.I have returned the shift to stock(with the program in),and it still does it.I really can't run the chip at all without the tranny acting up.Does anyone have a similar problem?I have a buddy with the exact same setup with no trouble at all.Is my tranny just going bad and I only see it with the extra horse?Please help if you can.
Old 11-09-2007, 05:20 PM
vitalidle vitalidle is offline
Desert Shield/Storm Vet
Well if you truck shifts fine without the bulldog hooked up then I would say its the bullydog, but thats just my opinion.
Old 12-09-2007, 06:23 PM
paul benton paul benton is offline
Anyone want to help here? I've got a 2003 f-250 and went to put it in reverse and heard a loud pop, real loud pop and then it would not move either way driveshaft don't turn noise is coming from tranny or the transfer any help would be great
Old 12-09-2007, 06:28 PM
dustindiesel dustindiesel is offline
if u want to check it out ur self u can start by pulling the trans pan off and see what the fluid looks like
Old 12-09-2007, 07:17 PM
Echo Echo is offline
Bullydog is known to be rough on transmissions. Sorry I'm no help.
Old 12-12-2007, 11:52 AM
darsey715 darsey715 is offline
Send a message via AIM to darsey715
LOLOLOLOLOL
Old 12-12-2007, 11:58 AM
bigwhite7.3stroker bigwhite7.3stroker is offline
Florida Stroker
I think it might just be the Bullydog I'd sell it and get a SCT Xcal2 or 3
Old 12-12-2007, 12:03 PM
hey you can't say that that's an opinion.
Old 12-12-2007, 12:46 PM
Florida Stroker
sorry man I just know a couple guys that have had bullydog stuff and had similiar problems and I know alot people like the SCT my buddy loves his.
Old 12-12-2007, 04:05 PM
I was being sarcastic. the OP said he didn't want opinions. lol
