Trannie help please - Ford Powerstroke Diesel Forum
Old 12-22-2012, 07:57 AM
Trannie help please
I got the code PO713 sensor circuit high input on my 05 F350 PS. Question.... Is this a serviceable part by dropping the pan and replacing a module or should I take it to ford for repair?
Symptoms are Tow/Haul light flashing, message center reads "check transmission temperature", factory transmission temp gauge drops to zero and the check engine light comes on. For a while it still shifts just fine but after a while, once you shut it off it goes into limp mode and won't shift past third gear.
Thanks
Randy
Old 12-22-2012, 08:06 AM
Illiana Chapter Director
I'd say the sensor is bad and it is replaceable. I'll look for a diagram.
Old 12-22-2012, 08:07 AM
Got it. I can't post pics on here but if you PM me your cell number, I'll try and text you a pic.
Old 12-22-2012, 09:01 AM
E-mails sent
Old 12-22-2012, 02:43 PM
Thanks for the information. looks pretty simple.
Randy
Old 12-22-2012, 02:55 PM
Yea its simple to do u might want to think about changing your filter while u have the pan dropped.
Old 12-24-2012, 10:10 PM
May as well change the frame filter since you have the pan off. No sense running clean fluid through a dirty filter.
Old 12-26-2012, 05:50 PM
trannie issue resolved... but wait
Ok. I changed the TFT sensor and both filters. Now , how do I get the CEL to go off? All else is working fine.
Thanks
Randy
Old 12-26-2012, 06:17 PM
Do you have access to a good scan tool or a buddy that has one?
Old 12-26-2012, 06:39 PM
No I do not.
