Desperately need tranny help
Transmission giving me all sorts of fits. Earlier it was throwing code p0730 and would rev up before basically slamming into gear. Now I just went to store and had to back out on a slight hill and it wouldn't go anywhere reved up really high and eventually slammed into gear incredibly hard kind of roasted tires and some not so good sound either hope I didn't break anything outside tranny but codes are in addition to p0730 are now
P0715 P0720 P0791 and actually no p0730 now oddly enough. And tow haul flashes Desperate need of guidance here thanks a lot!!!!! |
Wow! We have a whole lot of bad going on here, but there is a few options.
TCM failure Harness problem FUBAR trans First thing to check would be the condition of the fluid, if its burnt that would indicate failure internally. If not, you might be ok and you're having a connection issue, or TCM issue. Let me know what the fluid level and condition is. |
Yeah a whole lot going on here lol. Fluid seems to be at its normal level and be honest with you I can't tell if it smells burnt or not. Where would connections be and how can I identify if that's the issue. Where is TCM located? Thank you!!!!!
You work at ATS?
as for the connections, just check the trans harness, all of the connectoins going into it, and into the truck side. The TCM is the transmission computer, failure of it would be internal.
Ok will do that. I emailed a guy named Aaron from ATS about getting an ATS transmission. I use the truck for a lot of things. Sled pullin and drag racing included.
I am the Ford sales rep. You can call me at the number/ext in my signature.
Or email me at justin@atsdiesel.com |
Ok I will do that thanks.
Was told that it could be an issue with the PCM too any chance thats the case? I mean truck runs perfect other than the transmission.
