So, without thinking i posted this in the general 6.0 section. Ill post the link below, perhaps a moderator can put all this back together or something. Sorry for confusuion. Long story short, so you don't have to click on the link, 05 f250. Been loosing trans fluid, cleaned it and discovered it was leaking from the top of the transmission, which is kinda wierd. All temps, so i dont think its hot and boiling over per say, although trans temps are higher now...and no converter lock up, and flashing tow/haul light, and a p0741 code, torque converter lockup solenoid. I think that's just a issue with loss of fluid hopefully. Anyway, herez the link to the general 6.0 thread I did without thinking, it was 2 am, and I was very tired. Sorry again for the double thread ordeal. The link has more of the symptoms and all in it. Any help would be tremendously appreciated. Thanks.
5R110 Transmission Help
