New Tranny NO START - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-06-2012, 03:50 PM Thread Starter
New Tranny NO START
I just had the transmission rebuilt. I drove it home on the stock tune. When I got home I attempted to re-install the tune and no the truck will not start. I tried to reset again to stock but it still will not start. What's going on?
blown09gt500 is offline
post #2 of 4 Old 08-11-2012, 06:56 PM
Wed Turner's Avatar
Do you get lights and the injectors cycling? If so try setting the alarm on and off once or twice then start it. Every time I load a tune I have to cycle my facttory alarm.
2003 Excursion Limited 6.0 2wd
Transmission built by
/ ECM tunning by
/ FICM tunning by
Coldside Intercooler Kit /
EGR Delete /
Coolant Filter / GoGo Diesel direct clutch solenoid / AFE Stage II Intake / Ford Blue Spring / 6.4 Banjo Bolts / Zoodad / 1.5" front sway bar by
/ Ford 30mm rear sway bar
Wed Turner is offline
post #3 of 4 Old 08-17-2012, 10:28 AM
If you drove it home, and it shifted and everything is good, then it shouldn't be a problem with the transmission being as the only thing between the tranny and your engine is the torque converter and it doesn't engage in park.
Owner/Founder of Georgia Diesel Power.
Current Sponsors: QuickTricks Automotive, Ray Paul Powdercoating, Ace Transmission, SoCalTrucks.com
Current Member Count: 16
TheRobenator is offline
post #4 of 4 Old 09-12-2012, 09:15 PM
licenced2burn's Avatar
I had the same problem. Mine was a linkage or something like that under the column i had to tighten up i think it was 3 torque screws. If it will start when you lift up on the shifter thats probly ur problem
Tony
2005 F250 crew cab lariat,
4" lift 325/65/18 tires, head studs, built trans, egr delete, powermax turbo, 58v ficm from swamps with mild flash, 4" straight pipe, sct with innovative xtreme street and race tune's, blue spring upgrade
Stage 3, 190/100 injectors, and full fuel system on the way.
licenced2burn is offline
