wont come out of park - Ford Powerstroke Diesel Forum
post #1 of 8 Old 07-25-2012, 02:02 PM Thread Starter
6.0kansaspowerstroke's Avatar
Angry wont come out of park
For the last few months my truck has been fighting me when i try to take it out of park. Sometimes i have to sit there and wiggle the lever and pump the brakes for it to work. sometimes for minutes on end.
Its not the trannie fighting me but the gear shift lever. I looked in the owners manual and it said check all the taillight and brake bulbs and so i did and sure enough it helped my problem. Now its still fighting me and all my lights are working so i dont know what to do. To top it off i broke my parking brake release lever when i was trying to release it per owner manuals instructions to override the (parking position lock?) im not sure what its called.
Does anybody have any ideas on what it could be? also does anybody have the part number for the parking brake release lever?
04 f-250 crew cab xlt
5 inch turbo back
zoodad mod
foil delete
egr? what egr? O that thing i threw it in the recycling bin. See im still green
full bumper replacement
head studs coming soon
ride rite bags and flip over ball
hankook mt's 285's
SCT X3
custom tuned by innovative
edge insight cs
sinister coolant filter
blue spring mod
6.0kansaspowerstroke is offline
post #2 of 8 Old 07-25-2012, 02:15 PM
460+'s Avatar
Try to take it out of park with the key off but just turn the key enough to take it out of park. You dont want any dash power to do this. If that dont work, look at the end of the steering column where the shift cable attaches to the arm on the column. There are two torx bit screws that come loose. You might have to tighten them up.
99 F350 4x4 dually
7.3 w/K&N af
4" exh into 6" Aussies stacks
4"lift &35" tires
CC mod HP crossover line
Beans stage II 120hp injectors
D66 turbo
ITP regulated return
reburn on TS= 25,high idle,60,100,120,140hp
updated ecm (2000 model)
Dyno#'s 360hp and 965 ft lbs trq
460+ is offline
post #3 of 8 Old 07-25-2012, 02:28 PM Thread Starter
ill have to go out and take a look at it
5 inch turbo back
zoodad mod
foil delete
hankook mt's 285's
SCT X3
edge insight cs
blue spring mod
post #4 of 8 Old 07-25-2012, 02:28 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
I have the same problem with mine and I have to get out and rock the truck back and forth then hit the parking break then climb in and pull it out of park. PITA.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #5 of 8 Old 07-25-2012, 03:17 PM
powerstroke2501997's Avatar
maybe the brake switch on the brake peddle? i had that problem with a 96 f150 just had to replace that switch
Tony
1997 F-250
ts-custom chip, intake, 5sp, 4-5" exhaust
powerstroke2501997 is offline
post #6 of 8 Old 10-22-2012, 12:16 PM
I had the same issue on mine. Couldn't get the truck out of park. I replaced the brake switch down by the brake pedal and it has worked ever since.
2004 6.0 PSD, SCT tunes by Matt at Gearhead
New Heads, ARP studs, OEM headgaskets at 120,000
EGR Delete, New Oil cooler at 113,000
Coolant Filter kit
john3488 is offline
post #7 of 8 Old 10-22-2012, 12:31 PM
Send a message via Skype™ to bwmtnbiker
That is what I was going to say. I bet it has to do with the safety switch.
-Brian
2003 F-250 6.0L - Lariat King Ranch
-300k+ miles and still strong
Current Mods
-6.5" Pro-Comp lift
-Edge CTS
-SCT X3 (Tuned by Vivian
-4" Turbo Back Silverline Exhaust, 5"tip
-Blue Spring Mod
-Sinister Coolant Filter
-Oil Cooler
-Sinister EGR Delete
-OEM Cab Lights
Wants/Soon
-ARP Studs
-MTW Stage 1 or Hybrid
-6.4 Banjo Bolts?
bwmtnbiker is offline
post #8 of 8 Old 04-07-2013, 05:52 PM
B's Silverstreak's Avatar
Had the same problem with my 04. Replaced the brake switch and works perfectly
B's Silverstreak is offline
