Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Trannie problems
Old 10-06-2007, 07:27 PM
Jamie Foy Jamie Foy is offline
gettin' hot
My trouble is that when I tow anything over 5000 #'s, if my tranny shifts down, (to go up hills, or driving into a head wind while towing), if it doesn't shift up within a few minutes, the engine temp gets close to overheating. Trannie temp stays normal, tried using and not using tow/haul mode, but it still does it. Rad not plugged up, no grill inserts, Rad fluid is topped up, any help would be appreciated, before i go to dealer. Truck is a 2005 F-350 cc short box with 71,000 miles, all stock besides AFE filter and zoodad mod.
Old 10-06-2007, 07:49 PM
sldghamr sldghamr is offline
i would suggest avoiding the dealer unless it's your last option. my fuel pump when out a couple years back. ended going to the dealer bcuz it was my last option to figure what was wrong. they figured out that my pump went out. ended up costing my $2k.
Old 10-06-2007, 07:54 PM
720Deere 720Deere is offline
This is posted in a tranny forum, but your post reads like you're having coolant temp problems. What are the temperatures that you are seeing?
Old 10-07-2007, 05:20 PM
I don't have aftermarket gauges, as the truck is stock, but the engine temp gauge goes just before the red mark. The fan kicks in harder and of coarse a little power loss.
Old 10-16-2007, 08:55 AM
OkieFordFan OkieFordFan is offline
This is my first time here. I'm having pretty much the exact same problem with my '05 F350, 6.0. Please help!
Old 10-17-2007, 09:24 AM
Blue01F250 Blue01F250 is offline
Tournaments Won: 1
could it be fan clutch?
Old 10-17-2007, 09:58 AM
slammedSI slammedSI is offline
thats funny i had a strange problem with my 05 a few days ago, i was on the highway at 85 or so then started to here a loud roring noise. look at the tem guage and its climbing and fast slow it down to about 40 and it went back to normal. Never did it again.
But to answer the posters question, i would have the system flushed, if its not been done it should be. Also look into a coolant system filter. Dfuser.com is just about the only place i know that has them. Now if that dosent fix it i would look at the fan clutch, and go from there.
Old 10-17-2007, 10:09 AM
rajharley rajharley is offline
Member/MARINE
Send a message via Yahoo to rajharley
I do not know if I would avoid the dealership on this one. Just make sure to go to one that is mod freindly. And just my opinion...if you are towing you need better gauges than the stock ones. THe stock trans gauge is way off and will only tell you that it is getting hot when it is REALLY hot. Aftermarket gauges are much more accurate. I can see trans temps at 200 degrees on my autometer and the stock gauge will be half way up the temp reading where it normally sits. Having said that just imagine the trans temps you are having when the stock gauge goes just below the red.
Old 10-17-2007, 10:35 AM
Raul@Stealth Automotive Raul@Stealth Automotive is online now
+1 for a set of aftermarket gauges..... also you can get an engine oil cooler... the kit runs around 250.00 from Perma-Cool. it lowers engine oil temp up to 40 degrees
Old 10-17-2007, 07:29 PM
Evil Eye Evil Eye is offline
Slacker Mod
I would go with Brant on this one and think it's the fan clutch. Does your fan ever kick in? Trust me, you'd hear it if it did...
