tow/haul doesn't work - Ford Powerstroke Diesel Forum
Old 06-09-2012, 06:21 PM
So I thought my tow/haul light was blown out but I hooked my Snap On scanner up to the truck and when the button is depressed it will not activate the tow/haul. Anyone have any suggestions where to start. My truck is an 03 F250.
Old 06-20-2012, 07:59 AM
Tow/haul problem
Check the wires that go down your shifter into your steering colum. Mine did the same thing and when I took it apart there was a broken wire. Every time you shift your truck your bending the wires and eventually they brake. Hope this helps.
