06 6.0 shakes at take off, turns, uphill..
My truck: 2006 6.0 75,000 miles
EGR delete, exhaust, SCT, leveled on 35s When taking off from a stop, my truck shakes/ shutters? it only does this at low speeds, more so up hills going 0-15mph. Pulling a piece of equiptment it does it even worse starting from 0-15 mph. It shifts fine, goes fine at highway speeds and even cruising around town its only when I start out. Trans temp never gets above 132 degrees and around town it stays at 120 degrees. I am pulling a Jeep, 2 four wheelers, and a dirt bike 2 hours each way on Memorial day weekend and just seeing if I will be ok. I local Diesel shop around here wont touch the torque shift... one person said it may even be a carrier bearing on the drive shaft? ![]() thanks in advanc from one stroker to another! Last edited by nickhuts; 05-15-2012 at 01:58 PM. |
I had a shake like that and my carrier was bad but it was the bushing around the bearing. It was very noticable when I shook the driveline.
I just went out, crawled under there and shook my shaft...lol
Is there supposed to be any play in the carrier bearing? Its a loosey goosey |
My new one doesnt move around at all. Should solid in there and just rotate on the bearing. There is 2 different size bearings fyi.
holy crap! talk about hating salt! Took me 2.5 hours to get the thing off. Then after I got it off...guess what...wrong size lol It should be in tomorrow morning and it will be all good after I get a chance to put her back together after work. Thanks for the info guys!
Ya it took me awhile too. Would have been so much easier with a press
there should be no play in bearing. just curious have u checked to see if the bearing was hot to touch after driving truck for a good distance?
My truck did this today pulling a 4200lbs boat and trailer up a hill. My said it was probably the carrier. Is this a major problem? Is this something that needs to be addressed tomorrow or just before I tow again?
our 06 F350 SRW is doing this.. shudder going from gas to off gas mainly in overdrive above 50mph ish.. but i notice its got a shudder and funny squeek in relation to the driveshaft spinning off the line , the more apparent the more i get on it, more torque, the more you feel or hear it.
