what gearing do i have? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-13-2012, 09:47 AM Thread Starter
T Bone0416's Avatar
was wonderinging if theres a way to tell what my trucks geared?
07 f-250 Lariet 6.OH Powerstroke SB CC.
sct custom tunes from IDP.
Atlas 40 ficm
zoodad mod.
Studded
airaid air filter.
Egr delete
autometter nv gauges.
4 inch stright piped with 6 inch tip
ELC Coolant.
Rev X
6.4 Banjo bolts.
Blue Upgraded spring
AirLift Airbags.
Huskyliners.
High idle upgrade.
rotella T6 Oil.
Red tiop optima batterys
Leveled
350 blocks
20 inch xd hoss wheels
35 trail grapplers
T Bone0416 is offline
post #2 of 4 Old 05-27-2012, 06:07 PM
Like in the rearend? Open your door and look at the tag! There is a code mine says 3L that means 3.73 limited slip
My stuff!
Sinister egr delete
MBRB 4" TB straight
Blue spring mod
6.4 banjo bolts, headstuds
Powermax turbo
AFE cold air intake (dry filter),Zoodad mod.
Pillar gauge fuel press., volt, bully dog monitor mounted in it
Sct w/ custom tunes from Vivian looney,looney wild, tow with jb, track and compition file
20x9 eagle wheels w/ 35x13 nitro terra grapplers
Soon to be
190/75cc injectors
AirdogII i need to install but waiting on my injectors
meth injection
Msims02 is offline
post #3 of 4 Old 05-27-2012, 06:34 PM
the baconator
terryknight's Avatar
Quoted: 150 Post(s)
there should also be a tag on the rear end
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #4 of 4 Old 05-27-2012, 06:43 PM
The Silent Service
colo_dually's Avatar
Quoted: 30 Post(s)
First check on the door sticker, for code 3L which would have been the stock for a SRW '07. You can verify that with the tag on the axle itself.
If you're not the original owner, there is always the chance that someone swapped out the gearing before and never updated the two locations.
Any particular reason you are asking? If there is doubt you can always take your speed, tire size, and work back to axle ratio.
2007 F-350 XLT 6.0L PSD Dually 'Jezebel'
TorqShift 4x4 CC/LB 4.30LS - Tow Boss Package
colo_dually is offline
