big hesitation in reverse - Ford Powerstroke Diesel Forum
Old 04-14-2012, 07:44 PM
It's almost like it's engaging and disengaging. It started with a delay when I put into Reverse earlier in the day, followed by a slight stutter right when I gave it a little pedal in reverse that smoothed out quickly. I could make it stutter more/worse the more pedal I gave it right after the delay.
I had to back it out of the driveway and I waited for delay and let off the brake to let it push itself back a little bit but it would barely move so I gave a little push on the pedal and it was like a romping, it would barely back up, like it was engaging and disengaging. I had to limp it out of the driveway.
I didn't notice any noise from the trans area. I could slightly hear the motor revving while it wasn't backing up then sounded normal when it would engage but it was a noticeable BUMPing while slightly on the gas in reverse. I stayed steady on the pedal as I backed up about 50ft and it barely smoothed out with about 10ft left but it was a noticable chugging/hesitation that made it almost impossible to back it up.
Tow/haul never blinked.
Saving for a trans build now along with other fun things planned for this summer.
Old 04-18-2012, 10:17 AM
Making progress with this. Just ordered a couple solenoids. Crossing fingers that's it. But here is a clip I had my neighbor take hoping it would shutter enough to pick up in camera.
http://static.photobucket.com/player...-38-43_467.mp4
Sent from my DroidX using Autoguide
Old 04-18-2012, 05:05 PM
Powerstroke Techie
Feedback Score: 3 reviews
well I can tell you the direct clutch isn't controlled by a solenoid during reverse engagement, the manual valve is responsible for this.
Old 04-18-2012, 05:22 PM
Thanks Matt. Did you watch this clip I got of it. Look for flare followed by bang into gear at 13seconds and again at 16 seconds.
I'm worried about driving it because even in Drive if I come to a complete stop it might not want to go when I give it some pedal, it lugs and barely moves like it's in 5th or 6th then the rpm's will rise and it will drop a gear and seem normal.
Old 04-25-2012, 07:53 AM
https://docs.google.com/open?id=0B-r...29DdzA3WTFndW8
I'm having a very similar problem. Did you ever figure anything out?
Sent from my DROID2 using AutoGuide.Com Free App
Old 04-25-2012, 08:03 AM
Nope. Gonna swap in another 5r from an 05 in the next week or two. Also researching what iwill need to put a 4r behind it. Got time
