Which solenoid is C - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-28-2012, 11:00 AM Thread Starter
autotruckrv's Avatar
Which solenoid is C
My scanner says P0760 P0763 Shift solenoid C Short or open. I try to clear the code and It won't clear. Dealer does not know which solenoid is C
If you can't fix it, GET A BIGGER HAMMER
autotruckrv is offline
post #2 of 4 Old 03-01-2012, 03:52 PM
MO05SD's Avatar
Quoted: 2 Post(s)
Picture of Solenoid Assembly
Here is a picture of the solenoid body. It is the solenoid labeled 2 Intermediate Clutch SSPC-C from all the research I have done previously. Hope this helps. Feel free to PM me and I can send several pdf files I have found pertaining to replacement procedures. Hope this helps.
2005 6.0 PSD F-250 SC LB 4X4 Auto
Engine Hi-Idle Mod
AIRAID CAI, zoodad mod,
4" Turbo back exhaust
Coolant Filter & Flushed and changed to CAT ELC
Sinister EGR Cooler Delete
Banjo Bolts
Updated Fuel Pressure Regulator Spring (Blue)
ECM/TCM with VXCF4 Strategy
PHP FICM Programmer-(Economy,Atlas 40,Atlas 80,Hercules)
PHP Gryphon CTS monitoring ECT,EOT,TFT,Boost,FICM Voltage & 5 Custom Tunes
Fumoto valve
(Oil bypass filter system to be added next.)
MO05SD is offline
post #3 of 4 Old 03-01-2012, 03:55 PM
Quoted: 357 Post(s)
Feedback Score: 5 reviews
The one after A and B... duh
Hehe, sorry i just had to
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is offline
post #4 of 4 Old 03-03-2012, 04:24 AM
cook03f250's Avatar
Sweet pic, good info.
cook03f250 is offline
