Speedo quit working - Ford Powerstroke Diesel Forum
Old 02-27-2012, 01:13 PM
Speedo quit working
04 F250 4x4 speedo stops working and ABS light comes on at same time. Also odometer stops working. Any Ideas?
Old 03-03-2012, 11:25 AM
I'd guess your output shaft speed sensor?
Old 03-11-2012, 03:42 PM
Powerstroke Techie
Feedback Score: 3 reviews
rear diff speed sensor
Old 03-15-2012, 06:33 PM
Yeah, this is very common. Its either the speed sensor in rear diff or a broken wire going to the speed sensor itself. Usually gets kinked and brakes cover and gets corrosion inside.
Old 03-16-2012, 09:04 AM
Send a message via Yahoo to roustabout04
Having the same issue with mine. Changed out my sensor in the diff and still not working. Wires and harness didnt seem to be broken so idk. Hopefully you will get it fixed so i can follow suit. Good luck.
Old 05-02-2012, 07:54 PM
Any luck, Speed sensors are in the front hub assemblies as well as the diff. my speedo drops to 0 and then works but abs light stays on
