Torque Converter Chatters! - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-23-2011, 04:23 PM Thread Starter
I have a '04 6.0 with 278,xxx on it. Just last weekend i was stopped at a red light and when i tried to go my trans was slippin hard. so i babied the throttle and it went just fine. i checked my trans fluid and i was full and smelt fine. Now when the trans gets to operating temp the tq chatters upon take off. but if i slam the gas pedal up and down fast it makes a clunk and then everything works great. I had the same problem with my cummins and it was just the throttle body sensor. but the 6.0 doesnt have one. Any ideas?
6uhhoh is offline
post #2 of 6 Old 08-29-2011, 05:52 PM
I am inspired that you have a 6.0 with 278,000 miles on it !! What did you do to keep it going that long? Is this the factory transmission? Sorry I am no help at all on your question.
HAM_RADIO_MAN is offline
post #3 of 6 Old 08-30-2011, 04:51 PM Thread Starter
Change your oil! haha but just routine maintenance helps a lot. and yes its a factory trans. as long as you know how to drive your truck it will last you!
Here are some pics
6uhhoh is offline
post #4 of 6 Old 08-30-2011, 07:02 PM
NICE RIDE !!
post #5 of 6 Old 09-07-2011, 06:47 PM
thats super clean for almost 300,000 miles just shows how good fords are put together
Ryan
2003 2wd 6.0 egr gone, blue spring, extremeX
305/50/20 nitto 420s (lowered in the rear)
205/100 bw66
Boost got you loose
13.4 with a 1.9 60ft spinning anit winning
YOUR CUMMINS MIGHT BE FAST BUT YOUR GIRLFRIEND LIKES MY SLOW POWERSTROKE
my youtube channel mostly 6.0 videos
risco is offline
post #6 of 6 Old 09-08-2011, 07:10 PM Thread Starter
yes. except for my trans problem! please help. its almost like i have low trans pressure. when i get into the throttle there is a definite click sound from the trans and everything will work great. but once i return to cruising speed and try to accelerate again the same issues occur. i dropped the pan, pulled the valve body out, checked the shift solenoids, replaced the filters and fluid and no change.. is there a sensor that could cause this??
6uhhoh is offline
