Trans acting up - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-24-2011, 03:46 AM Thread Starter
04stroke's Avatar
Trans acting up
So I took a trip to georgia with my 24 foot trailer and 4 quads nothing crazy heavy..the whole trip there, no problems I switched between a few custom tunes to try n get best towing and fuel mileage but ended up just running my street race tun...well on the way home in florida I made a stop at the rest stop to switch drivers and got on the highway n the truck wouldn't go into over drive..I thought it was just the driver then we pulled back over n I drove..same thing..pulled over shut the truck off..continued driving and now I have over drive..trucks been fine ever since then..but now 5 days after I unhooked from the trailer and this morning it was in drive and when I would let off the throttle n it had that deceleration feeling like it was in first..and the shift pressure is fine but in between shifts it goes all threw the rpm range as if I was towing, no slippage just doesnt shift at say 1650 rpm from first to second or second to third..and also wouldn't go into over drive this morning..haven't had time to scan it yet just figured I'd post to see if anyone has any ideas or has had the problem before
Thanks for any input
2004 F-250 5.9
97 12 valve P-pump tuned,4k and worked!
04stroke is offline
post #2 of 3 Old 07-29-2011, 09:42 AM
Bump, my trans is doing the same thing. When I get some time today, im going to load the truck back to stock and drive it for a while and see what its gonna do. Its been happening in 8K Gearhead, gonna give SRL a try cause it uses torque lock up a LOT, if it aint working it may be the DD solenoid.
Kobane is offline
post #3 of 3 Old 09-06-2011, 09:57 AM
Carnag3's Avatar
Send a message via AIM to Carnag3
so did you end up rebuilding your trans and how much did it run you?
~Carnage~
Carnag3 is offline
