having a little trouble getting torque converter nut loose on 2004 ford f350 any help is appreciated
acces the nuts from driver side there is small plasic cover you can remove opposite side of the starter above alluminium (upper)oil pan i hope this helps
thats the same method on the 4r/e4od trans
a 15mm semi deep socket and 3/8s drive ratchet should work. there should be an access hole on the very bottom between the bellhousing and oil pan
what else will help is a long 18mm 15° offset box wrench to spin the crank pulley |
thank you to you all the hole between the motor and trans isn't working so good i've gotten three loose just can't get a good square shot at it are you sure there is one on driver side opposite starter have looked a little but not since reading our response thanks again
