Need help with tranny probs and codes!! - Ford Powerstroke Diesel Forum
post #1 of 7 Old 02-04-2011, 02:55 PM Thread Starter
DeWitt's Avatar
I have an 05 f250 and today it decides it wants to flare up between 3-4 gear and is hard shifting into other gears. Also puttin into reverse it slams hard then kinda chugs and jumps backwards. Its to the point now where it locked itself in tow haul and wont go into overdrive just revs up and the tow haul light just flashes. I have 4 codes I have no idea what they mean. They are P0404, P0405, P0766, and P2703. And help is appreciated guys I need it thanks!
2005 F250 Lariat
Sct- Loony for Dj and Spartan tunes
4" straight pipe
K&n intake
High idle mod
35" Fierce Attitude M/T
2'' Leveling kit
and alot to come
DeWitt is offline
post #2 of 7 Old 03-10-2011, 10:43 AM
I have the same problem going from 3rd to 4th it did it for the first time last week. I pulled over and turned it off and turn it back on and it worked fine again and it did it to me again today. So if you find out please pass along the information
willifordc08 is offline
post #3 of 7 Old 03-10-2011, 10:48 AM
Slacker
Evil Eye's Avatar
Quoted: 233 Post(s)
Feedback Score: 4 reviews
Sounds like the direct drive solenoid is on it's way out. The first two codes are EGR related so not related to your tranny problem. I got a new one from Doug @ Gogo Diesel. Basically, when you start getting these kinds of codes, your tranny is likely living on borrowed time so be prepared for your tranny to start having problems.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #4 of 7 Old 03-11-2011, 01:13 PM
Quoted: 4 Post(s)
Feedback Score: 5 reviews
If your planing on modding for more HP...Time for a BTS..
CT Performance, Inc. is offline
post #5 of 7 Old 04-08-2011, 09:25 AM
tbdafoe's Avatar
@DeWitt and @Williford, what did you guys find out? I just had the same issue yesterday on my 03Ex, hard shift from 3 to 4, and wouldn't go into overdrive with Tow/Haul flashing. Dealer agrees with Evil Eye, says its the Direct Drive Solenoid, and if not, then we're talking tranny R&R.
I checked codes with my MiniMaxx, cleared them, and they came right back. Hard Failed. Like an idiot, I checked them again, same code, drove to the dealer and removed the MM without writing the code down! Now I'm at their mercy...
Solenoid is being installed today, hoping for the best.
03 Excursion 6.0L 4WD, K&N CAI, 4" TBE, H&S MM. Kid hauler. Wife's truck.
08 Dodge Cummins 6.7L 4WD, 3500, QCLB, Banks/K&N CAI, 5" TBE, H&S XRT, G56 with a Valair DD Kevlar clutch on the shelf waiting to be installed.
My truck.
tbdafoe is offline
post #6 of 7 Old 06-25-2011, 03:17 PM Thread Starter
DeWitt's Avatar
Tbdafo, did that solve your problem?
2005 F250 Lariat
4" straight pipe
K&n intake
High idle mod
2'' Leveling kit
and alot to come
DeWitt is offline
post #7 of 7 Old 06-28-2011, 10:49 AM
tbdafoe's Avatar
Yes, drive solenoid replaced, tranny flushed, haven't had any issues since. She's runnin like a champ!
My truck.
tbdafoe is offline
