Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Trannie problems
Old 07-09-2007, 07:05 PM
friedel friedel is offline
Relearning the transmission
I have been told that you can do a sequence of putting the gear selector into different gears to have the tq shift learn how the driver uses the truck. I have a programmer and exhaust. Can anyone help me on this!
Old 07-09-2007, 07:16 PM
ABOBB ABOBB is offline
Is it even worth it???
Don't know anything about the transmission thing, but
Welcome to Powerstroke.org
Old 07-09-2007, 07:18 PM
sea71 sea71 is offline
An old method was to unhook the batts for 30 mins or more so the puter could "forget", hook batts back up and then drive as you normally would.
Old 07-09-2007, 07:19 PM
Well my tranmission has been feeling like it is slipping since i put the programmer on it and a buddy told me that i could make the transmission relearn itself
Old 07-09-2007, 07:23 PM
should i take the programmr off of it before i do that or does it matter?
Old 07-09-2007, 07:26 PM
I dont hink it would matter, but I would just to be safe. Also, the relearning process just lets it learn your driving habits, and it adjusts shift points ,etc to the way you drive. I dont believe it will help with any slipping issues.
Old 07-09-2007, 07:27 PM
WD40 WD40 is offline
Please feel in your Signature so we will know what kind of truck we are talking about and also where your from. Thanks and Welcome to the Org.
Old 07-10-2007, 02:11 AM
darsey715 darsey715 is offline
Send a message via AIM to darsey715
what kind of programmer are you using? Is it a stock tranny? Any problems in the past with the tranny? I think, if your tranny is slipping then it's slipping. unhooking the batteries will erase your kam and I've read it takes around 500 miles for the pcm to relearn your driving habits. good luck.
