- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
Trans Temp Gauge Pegged to Red
What does Trans Temp in red, Check Gauge illuminated and Tow/Haul On Blinking indicate?
Driving under normal conditions for about 6 miles when I noticed the Check Gauge indicator was lit up. The Trans Temp Gauge was pegged to Red and the Tow/Haul On light was blinking. I would have noticed the gears working within a minute had I left Tow/Haul On so I assumed it was off. I pulled over shut down, restarted, back to red. Pressed the Tow/Haul button to off, light still blinking. Drove around the block trying Tow/Haul on/off to see if anything would change. No luck but I still felt I was in Tow/Haul Off. I limped home and checked the Trans Fluid it was OK. This morning I started up my truck and the temp did not go off the chart. This tells me that sucker was Hot or the gauge could have a fluke but I doubt it. I checked the radiator for debris but it was all clear. I was not in 4WD. Is my tranny about to have a meltdown ? This blows. I just got it back last week after having the ball joints replaced. Odometer is about 50,000 Last edited by rondon600 : 05-11-2006 at 05:37 AM. |
| Sponsored Links |
stock trans temp
My experience with the stock gauge is that it does not move until things are getting in the danger zone. Not long ago while 4 wheeling on Velano Beach my Speedhut trans temp gauge was moving close to 280* while the stock trans temp did not budge from it's normal position. Under normal driving conditions my trany temp never gets above 160* and I live in Florida so it's always hot as far as this Yankee is concerned. Something is definitely going on with your truck but I would invest in an aftermarket gauge that will give you true temps at all times. Scott |
something to add when I drove it again not only did it peg red but it started bouncing from normal to red a couple times. I had a hunch the sensor was faulty. Im under warranty so I dropped it off earlier today. Already had a call back to say it was something faulty in the electronics. thanks for the quick replies. Ill post exactly what it was when the work is complete. |
So whatever was the problem with the truck then??? I am having the exact same issue with my 03 f250 6.0, with 74k on it. Also what a concedence?? Started after having an oil change done, two injectors and Balljoints!!! Funny also; the trannys not covered under warrenty any more.....or so ive been told; but I could swear it was 100k Powertrain warranty?? wouldnt it include the tramsmission??wtf.
sorry for the delay. here is what happened as described on the service invoice. CAUSE: 53529 DIAG TRANS OVERHEATS AND CEL ON WDS TEST P0713 MONITER PIDS FOR TEMP SESOR PEFORM PINPOINT TEST B1-B7 ELECTRONIC TRANS DIAGNOSIS R@R TRANS PAN REPLACE FLUID TEMP SENSOR SHORTED TEST DRIVE ALL OK CLEAR CODES AND RETEST PERFORMED: 7000F- Auto Trans Electric Diag 7000F2- Auto Trans Pin Point Test 7191a11- Auto Trans Fluid Temp Sensor Replace (7h141) 7191a- Auto Trans Gasket Remove and Replace (7a191/7a194) 7191axq Auto Trans It was covered under warranty. I forgot to ask if it was the 100k warranty but I am assuming so since they didnt bang me for $100 deductibel which is the case for things that fall under the extended warranty I purchased. Last edited by rondon600 : 06-02-2006 at 11:19 AM. |
Transmissiong gauge
$$$591.00 Later and more than a WEEK with out my truck exactly what you said temp sensor in the tranny. Im a little pissed at the price of this repair; not to mention I [i]told them[i] what it was and they outright refused to order the parts first.
| Sponsored Links |
