will a 7.3 trans bolt to a 6.0
Well just wondering if a 5 speed transmission from a 7.3 bolt to a 6.0 engine.
as far as i know, you will have to get an adapter.
do you know what type of an adapter and where i can find one.
why are you wanting to do this?
you will need a different bell housing, most likely tranny mounts, drive shafts, computer to control the transmission. seems like a lot of hassle for a weaker transmission. |
right now i have a 2005 6.0 powerstroke 5r110 what would be a good manual trans to couple up to this or is the 5r110 real real strong trans
5r110 is good stock, but has a lot of room for improvement. Now for towing or the fun of slamming gears, the zf6.
well i dont very much towing but i have alot of power and i dont think the 5r110 will hold up to me having fun
This topic has been covered numerous times before. The 6.0L engine with the 5R110 automatic uses a completely different rear engine cover and PCM from the manual transmission versions. To convert it to a manual is far more work and far more costly than simply selling your automatic and buying a manual 6.0L truck.
Alot of power ? care to explain this first
cheaper just to build the 5R110W when it burns up
