Tow haul flashed... truck unable to start. Need help fast! - Ford Powerstroke Diesel Forum
Old 10-10-2010, 10:29 AM
I am currently broken down on the side of the highway with my 2005 F-350 super duty. I recently had my transfer case replaced, and shift motor. I was passing a vehicle, and the truck seemed to slip. The tow haul light began flashing, and I lost substantial power. I guess safe mode? My engine temperature also rose dramatically, so I pulled over to asses the situation. I shut down the truck, and am now unable to start it. I have disconnected the batteries, and reconnected them, but no success. I have plenty of power, and all my fluids are good. It just seems as if there is something preventing power to the starter. How can I bypass this to get my truck fired up. I am sure this is a safety feature that has been engaged.
Old 10-10-2010, 10:53 AM
torqshift's dont have a safe mode to my knowledge sounds like you got some sort of other problem
Old 11-18-2010, 05:08 PM
solutions?
Kingranch89
did you ever find out what your problem was? mine just did that today. its sitting in my shop. only got it to fire up with the screw driver to the starter, but it stays in high idle and the TOW HAUL is flashing.
