trans big problems been in ford for over a month 1/2 - Ford Powerstroke Diesel Forum
Old 10-05-2010, 04:12 PM
ok here it is.Trans started up shifting and down shifting on its own one day.Took it to the dealer pulled trans out and said overdrive clutch was shot replaced all clutches overdrive solinoid valve body and converter so its pretty much a whole new trans.well did not fix problem.at first he was getting code for overdrive solinoid stuck closed after work he get overdrive solinoid stuck open.He said he did an overlay and everything was fine.he cant figure it out.
he said when he puts it in reverse its acually going into overdrive i think witch would be second i guess its not going into first, if im saying it correctly.when it shifts it seems like in the middle of the shift it wants a gear thats not there.ive been without my truck for almost 2 months if anyone has any idea it would be apprciated. thank you
Old 10-05-2010, 04:34 PM
anyone got anything on this
Old 10-05-2010, 04:58 PM
All these techs on here and no one has any info i really could use some thanks
Old 10-12-2010, 01:25 PM
a month and a half??? Go to the shop tomorrow and say, "I'm here to pick up my truck. If it's fixed, fine, if not, I'd like all my money back." Then take it to someone else.
Old 10-14-2010, 02:24 PM
x2 on that one either they need to get you fixed in 1 day at this point or your taking it and not paying anything and going elsewhere to get it fixed.
