Tranny doesn't want to shift from PARK - Ford Powerstroke Diesel Forum
Old 10-02-2010, 12:47 PM
Transmission doesn't want to shift out of PARK. I need some place to start looking, it's like it doesn't think you're pushing the brake. I don't know.
Old 10-02-2010, 12:51 PM
Did a little more research. Where is the brake switch located?
Old 10-02-2010, 01:11 PM
Old 10-03-2010, 03:14 AM
Bumping it back up. Apparently the tranny forum doesn't get many views. Maybe it'll catch someone's eye this time on the homepage.
Old 10-03-2010, 04:05 AM
look at the fuses under your dash...mine did this last week, I replaced the fuse and it went back to working properly.
Old 10-03-2010, 08:50 AM
Look under the dash whille pressing the brake pedal. Youll see the switch mounted close to the arm or on the arm. Usually a broken wire right where the wire goes into the switch.
Old 10-03-2010, 10:11 AM
I'll check it out. Thanks men.
Old 11-08-2010, 06:10 PM
I HAD THE SAME PROBLEM IT WAS THE BREAK LIGHT SWITCH THE CONTACTORS WERE BAD
Old 01-07-2011, 06:45 PM
mine is also doing this, only happens some times though, other times it works fine, what should I look for?
Old 01-10-2011, 03:23 PM
Right where the wires go into the brake switch,, they break. Sometimes, you have to take the switch off to see it.
