tranny don't want to shift
I just bought a 06 and the tranny don't want to shift when it cold i have to speed up and then let off the gas to get it to shift. I does this intill the tranny temp is in the normal operating range after that it shifts great. pluged filter?
Same Issue
I've got the same problem on an 2006 with 77,000 miles. Anyone want to chime in to help.
Do you have a tuner? Have you had it serviced?
Mine holds onto shifts about 100-250 RPMs higher when its cold. |
same issue! any fix? or just take it to ford?
2005 6.0 125k here and does same thing when cold since almost a year or so old.
After it shifts the first time ( 500 rpm or so higher or until I blip the throttle some ) , it usually doesn't do it again ? |
Looking at an 05 and it's doing the same thing????? Ideas? I've heard of a bad injector causing something like this... any truth to it?
I don't known Kevin ?
It seems if it were an injector it would stay running crappy ??? Mine just does it once in awhile after it sits on really cool / cold day for several hours overnight , after it shifts the first time it dosen't do it again .. |
I've heard and read in a couple of other threads on here where the culprit was a bad injector. I agree with you, if it would be an injector you would think it would be all the time. I see allot of people with these problems but not allot of input. I've also heard that selinoids can be the problem too. I am going to keep researching this and see what I can find out.
I was told by Service Tech. it is probably a sticking solinoid in tranny when cold. Since mine is out of warranty ..I'll live with it !
I hear their not that expensive, now as far as how easy they are to change??? I'll keep you posted. |
