Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Trannie problems
Old 04-23-2006, 12:40 PM
dieterbear dieterbear is offline
Angry tranny trouble
I bougth a used 2003 F350 6.0L in August 2005. It had 12,000 miles on it. The day after I bought the truck it would not start. Dealer put a injector in it. I have heard that is a common problem. Then last month I took it in for the recalled and asked them check a squeak it had. They told me it had a bad thrust bearing and put a short block in it. I finally pick the truck up on friday after they had it for more than a month. two day later I had the cruise set and suddenly the engine revved. It will know not move at all. Has anyone heard if these problems have occurred before or if this is just a bad apple. Thanks for any help I am getting a little frustrated.
Old 04-23-2006, 12:50 PM
mschn99 mschn99 is offline
we have had virtually no problems with the torqueshift trans. they are pretty simple with electric solonoids that pretty much engage and disengage everything. either you have a solenoid that has failed or a hard part internally broke......but this is one of the first major problems i have heard of since the trans switch.....Marc
Old 04-23-2006, 12:58 PM
more on the tranny
Is there something that could have happened while putting the engine in that caused this. when i first picked the truck up and took of it would not down shift with the cruise on but i turned the cruise off and on and it began working.
Old 04-23-2006, 01:14 PM
i suppose its not impossible.....but its pretty unlikely. just for my info....have you checked your fluid level??
