- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
Fixin' to break something!!!!!!!!! (Transmission trouble)
My truck started leaking fluid out the back passenger side of the trans pan. It leaks so much fluid while driving that it's coating the bottom of my truck with 8 dollar a quart ATF!!!!
Today I replaced the gasket with a new Ford gasket, and put in 7 quarts of Amsoil universal ATF (SP safe). I drove it around the block and when I pulled into my driveway I noticed a stream of fluid behind the truck. I lost about 60 dollars worth of fluid dammit!! I am so angry!!!!! ![]() What could be causing this?? The pan is still leaking even with a new gasket, surfaces were prepped and cleaned, and I torqued the bolts in proper sequence to 120 inch/lbs. Has anyone had this happen to them, why is my pan leaking!!!? I am pissed off......... If the trans. bypass filter at the front of the truck is too old, could that cause pressure build up inside the transmission? Please help me if you know what could be causing this. I need my truck for transportation and I can't afford to lose so much transmission fluid trying to drive it. Is the pan capacity really 7 quarts?? Last edited by TexasKingRanch : 06-25-2007 at 12:08 AM. |
| Sponsored Links |
I went out and wiped the transmission down with a rag and drove it down the street, it leaks quite bad. It appeared to be coming from above the pan and I spotted a small hole in my transmission case! By the way it looks it may have been punched in by a large flathead screwdriver or by a flat steel punch. WHAT -THE- HELL. I will try to take a picture. Totally unbelievable. Something in my gut tells me someone screwed with my truck. I know where it's been, and exactly when it started leaking. I could never imagine doing something like that to someones property. |
in my old truck... 2002 f150 cc i had a real bad leak with the tranny.... every time i drove it ...it would slip all over the place and just dump fluid like a dam waterfall... changed the gasket... torqued the bolts in sequence still was doin it so i got a flashlight and strarted looking around on top of the tranny... maybe a line or something....low and behold it was my god dam dip stick tube came out of its hole on top of the tranny and was pooring fluid out like no other..... just though i would share that wth you ... maybe something you should lookinto
Man I hope that's not it. That would be some real B/S if it is. I'd be nail spittin' fighting mad. ![]()
| Sponsored Links |
