Transmission service - Ford Powerstroke Diesel Forum
post #1 of 14 Old 04-22-2010, 12:02 PM Thread Starter
wnsniper's Avatar
I went to my dealership to pick up fuel filters and thought I should check on getting a transmission service. I was quoted $385. For this they drain the fluid in the pan, drop the pan, replace both filters and put in 8 quarts of fluid.
I thought this was high for a tranny service so I thought about doing it myself. When I spoke to the parts guy and asked for the recommended fluid he told me to use Mercon LV. I thought we were susposed to use SP but he said no more and he said LV is compatable with SP if I was not doing a flush.
Any thougths or suggestions?
2004, 6.0. 66K Never did a tranny service to date.
wnsniper is offline
post #2 of 14 Old 04-23-2010, 08:21 AM
BDSford03's Avatar
yes, the LV (low Viscosity) is compatable with the SP. AMSOIL also offers the LV fluid.
2008 ECLB FX4 all stock
Planning on: Spartan, full 5", EGR delete, 6"on 37's
BDSford03 is offline
post #3 of 14 Old 04-23-2010, 11:38 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
I'd use the SP...
CT Performance, Inc. is offline
post #4 of 14 Old 04-25-2010, 06:57 AM Thread Starter
wnsniper's Avatar
I ordered the filters and Mercon Sp from Dieselfiltersonline.com. They seem to have the best prices and they said they are Motorcraft. I ordered the FT-144 (Internal pan) and the Ft-145 (External) and a case of the Mercon SP. They also listed an FT-157. What the heck is this filter and do I need it?
wnsniper is offline
post #5 of 14 Old 04-26-2010, 03:11 PM
Quoted: 3 Post(s)
You only need 8qts
FT-157..SKU: FT-157
Manufacturer: Motorcraft
Ford number: 3C3Z7B155AA/4C3Z7B155AA
Part Type: Tranmission Filter
Fits Year(s): 2003-06
Engine Type: 6.0 Liter
Its a external thats all I know..
post #6 of 14 Old 04-26-2010, 03:57 PM
JER-1's Avatar
Quoted: 17 Post(s)
Cool
If you flush it all out and do it correct you need 18 qts.There's a writeup on here somewhere on doing it did mine a year ago.
Pan inside filter and inline filter small up around the front of truck I think pass side , on inline remove the cover and install new paper filter it's not a spin type filter.
JER-1
FOR SALE $19,000
2005 F-350 DUALLY
SUPER DUTY XLT
4X4,CREW CAB 8' BED
FACTORY TOW COMAND BRAKE SYSTEM
FACTORY UPFITTER SWITCHES
EDGE EVOLOUTION 11 GAUGES BUILT IN ONE
ACCUFAB INTAKE MANIFOLD
ZOODA MOD
KITTY RAN OFF
85,600 MILES, 4.10 REAR
PREVENTIVE MAINTENENCE BELOW
SINISTER EGR DELETE
OIL COOLER REBUILD
STC FITING IN HPOP REPACED NEW UPDATED ONE
COOLANT SYSTEM FLUSH 2015
NEW CAT COOLANT 11/2015
DIESELSITES COOLANT FILTER SYSTEM
7 NEW NITTO TERRA GRAPPERS
BLUE SPRING UPGRADE
JER-1 is offline
post #7 of 14 Old 04-26-2010, 07:13 PM Thread Starter
wnsniper's Avatar
I wasn't planning on doing the full flush, just replace the 8 quarts from the pan. I ordered 12 quarts to have extra on hand. I have searched everywhere and have no idea what filter FT-157 is for but it is listed for my truck.. I'll probably double check the filter numbers with the dealer.
wnsniper is offline
post #8 of 14 Old 04-30-2010, 04:36 AM
denhammkc's Avatar
I am changing my FT-145 the external that looks like a roll of toilet paper. I am having a heck of a time getting that aluminum bell shape housing that it sits in, off. I t is really tight and when I put some torque to it the bracket it is mounted to flexes.
Any ideas how to get the sucker loose.
Kurt From KC:
2007 F350 SRW CC LG BD
Airaid intake/ Zoodad Mod/ AMSOIL bypas oil filter
Mag-Hytec Trany pan, Front & Rear Dif covers
MBRP 4" turbo back (lost the cat) 5" tip
SCT Livewire runin Innovative Diesels tunes
Strait up pipe / EGR cooler blocked/caped
Coolant filter / Trany filter / CCV Mod /
ARP Studs
Blue Spring upgrade / 6.4L banjo bolts
Riffraff CAC boots
Upgrade to metal cold side CAC tube
DELO ELC coolant
B&W turnover ball with 5th wheel adapt.
35' Sundance 5er
denhammkc is offline
post #9 of 14 Old 05-01-2010, 06:05 PM
JER-1's Avatar
Quoted: 17 Post(s)
Cool
JER-1
FOR SALE $19,000
2005 F-350 DUALLY
SUPER DUTY XLT
4X4,CREW CAB 8' BED
ZOODA MOD
KITTY RAN OFF
SINISTER EGR DELETE
OIL COOLER REBUILD
BLUE SPRING UPGRADE
JER-1 is offline
post #10 of 14 Old 05-02-2010, 08:52 PM
6.0DSLPWR's Avatar
Best way to get the external filter undone is a impact gun. Usually one hit with the impact is enough to break the filter loose. Dont tighten the filter with the impact though.
-Aaron
2005 Ford F350
SCT X3
Isspro Performax Gauges
Dieselsite Boots
Fumoto Oil Drain
Coolant Filter
MBRP Dual 4" Straight Pipe
Harley Headlights
Pioneer In Dash GPS
6000K HID Headlight and Foglights
Smoked Lights
6.0DSLPWR is offline
