Gear Indicator Stuck - Ford Powerstroke Diesel Forum
Old 04-12-2010, 10:32 AM
I have a 2006 F250 6.0, automatic transmission.
The gear indicator is stuck to the right of 1st gear. Not sure how this happened (just got it back from having a parrot kit installing it and the problem was there).
Any ideas on what they could have done to cause it and/or what to do to fix it? I can still shift it, but I just have to know P, R, etc...which is a pain.
Thanks,
Chad
Old 04-12-2010, 10:46 AM
Take off the bottom of the steering column, theres a little wire thats looped on there, if the wires off of the shifter theres your problem, or it might have gotten pinched and broken somehow.. you might need to take out the bezel around the guages and take the top off the steering column, check it out
Old 04-13-2010, 04:37 PM
That's exactly what it was...thanks again for the help! You guys are the best!
