03 ZF6 manual with 06 6.0L Powerstroke - Ford Powerstroke Diesel Forum
Old 03-13-2010, 10:11 PM
is it possible to swap a 03 ZF6 to a 06 6.0L Powerstroke?
Old 03-13-2010, 10:15 PM
Feedback Score: 4 reviews
You must be wanting to swap tranny's from one to the other. They will bolt right up, but the electronics might be a little tricky. It also depends on if the 03 and the 06 are the same cab configurations. If the are the same you will just have to transfer the tranny, transfer case, and drivelines over because I don't think the trannys are exactly the same length.
Old 03-13-2010, 10:18 PM
yeah I'm wanting to swap transmissions and I have believe I have everything needed to swap transmissions but I've heard i have to swap all the computers.
Old 03-13-2010, 10:30 PM
Now I'm Strokin6.4Liters
Feedback Score: 8 reviews
You can get the PCM reburnt at ford
Old 03-13-2010, 10:40 PM
sweet! thats awesome thanks!
Old 03-13-2010, 10:46 PM
You do know that you also have to swap the transmission tunnel out of a manual because a manual tranny is taller
