Why won't tsmn shift after first starting? - Ford Powerstroke Diesel Forum
Old 02-10-2010, 07:25 PM
RMG RMG is offline
Why does tsmn not want to shift smoothly after first starting 06 6.0L diesel auto tsmn? It'll go screaming for first 100 - 200 yards through gears. After that it seems to do fine. Fluid level ok. Changed fluid & filters. Why is it doing this?
Old 02-10-2010, 07:30 PM
It's cold? Gotta let this stuff warm up first
Old 02-11-2010, 10:29 AM
RMG RMG is offline
I have been warming up engine anywhere from 5 to 10 minutes. Usually engine will go into fast idle within 5 minutes.
Old 02-11-2010, 04:01 PM
But that doesn't warm up the transmission. It does but not a lot. The torque converter will spin in park but not enough to warm the WHOLE thing up. What do you mean screaming?
Old 02-11-2010, 04:18 PM
Mine is like that also when it's cold, like under 40. I have to drive it about 3 miles before the torque convertor will lock up. Then it's fine.
Old 02-11-2010, 04:25 PM
Yea but he's got a 5R110. Same idea though, the TC won't lock until the temps are up to a certain place. Best thing to do is drive it easy until then.
Old 02-11-2010, 05:11 PM
Should i be concerned that my trans. will be at operating temp before engine temp even gets about the C? Sometimes they warm up almost evenly then sometimes the trans. will still be cold and the engine will almost be at operating temp.
Old 02-11-2010, 05:23 PM
Shouldn't be a bad thing
Old 02-11-2010, 05:37 PM
That transmission temp gauge is no more than an idiot light. Ince the transmission reaches a certain point it starts moving to the middle, and once its overheating it will all of a sudden move to the yellow. Its not proportional to the actual temperature.
Old 02-11-2010, 05:39 PM
ok thats good to know thanks
