filter change question - Ford Powerstroke Diesel Forum
Old 01-15-2010, 03:54 AM
When changing the automatic transmission filters how many quarts will it take to replace the fluid?
Old 01-15-2010, 05:17 AM
Slacker
Feedback Score: 4 reviews
How many miles do you have on your truck? Bypass is every 15k miles and fluid change is every 30k miles. I don't recall if the pan filter is supposed to be changed at 120k or not, because I haven't gotten there yet. In total it will hold 16 quarts of Mercon SP fluid (only seen it available from Ford), and with a bypass and fluid change, it usually takes me between 8-10 quarts.
Old 01-15-2010, 10:17 AM
Chapter Director
What do you mean by "a bypass"?
Old 01-15-2010, 10:43 AM
43,000 and some change.. i have 10 qaurts at home.. i was going to change both filters, but i guess your saying i should only change the toilet paper one and drain and fill the tranny pan..
Old 01-15-2010, 10:49 AM
This is probably the most popular method for filter changes / transmission flushes:
1) Drain transmission fluid
2) Change external filter (toilet paper)
3) Refill transmission (approx 8 quarts)
4) Drive truck for 20-30 minutes
5) Drain transmission
6) Refill transmission (approx 8 quarts)
The transmission holds 16 qts but you won't get much more than 8 qts out when you drain.
As mentioned previously, the internal filter only needs to be messed with when you're rebuilding the transmission. Its more like a big open screen than a filter.
Old 01-15-2010, 10:57 AM
Chapter Director
How do you drain the fluid? Is there a plug or do you need to drop the pan? By the way, my truck is a 06 6.0L
Old 01-15-2010, 11:01 AM
there is a plug in the tranny pan..
Old 01-15-2010, 01:20 PM
Slacker
You really only need to do steps 1-3 if you are changing every 30k miles. If not, I would agree.
Old 01-20-2010, 09:34 PM
Change the filter in the pan also. Allways!!!!!!!!!
Old 01-21-2010, 06:06 AM
Slacker
The FOMOCO service procedure doesn't specify to change it through the 30, 60, 90k service intervals. For most vehicles I would whole-heartedly agree with you, but not in this case.
