Transmission Service Questions - Ford Powerstroke Diesel Forum
Old 01-14-2010, 11:32 AM
Chapter Director
I have a 2006 Ford F250 PSD with an automatic trans that is due for its tranny service. Called the local dealer and they quoted me a price of $189.00 for a reverse flush and fill with new fluid. I asked if they replace any filters and they said no, they do not need replacing. Is this correct? My truck has 98,000 miles.
Thanks!
Old 01-14-2010, 11:53 AM
Just took mine to southeast diesel and had the same thing but they drop the pan replace the filter clean the pan and ump all old fluid out for that.....unfortunately for me they said I had chunks of metal in the pan...Im about to go pick it up along with the zip lock bag of metal along with it!
Old 01-14-2010, 11:55 AM
Chapter Director
What a bummer! How much did they charge you for that level of service?
Old 01-14-2010, 12:00 PM
He told me between $190-$210..I'll give ya an exact # in about an hour..picking up @ 430
Old 01-14-2010, 12:02 PM
Of course the filters should be changed, pan should be dropped and mag cleaned of metal shavings/particles. also not sure what a "reverse flush" is, you'd be better off to buy the filters and about 8 qts of sp ot lv, and doing it yourself.
I think what they might mean by the term reverse flush it a fluid exchange through the dip stick tube, all machines I have seen have a pan removal function built in, so no reason to be lazy and not change the filters
Old 01-14-2010, 12:14 PM
GAS GAS is offline
heck ya, do it yourself!!
make sure to look to see if your truck has a drain plug on the converter, I believe all the fords do. That will get even closer to a 100% fluid replacement.
Old 01-14-2010, 01:49 PM
242.47 for everything they had to use around an extra 5 quartz doing the pressure testing...Im going to buy a new tranny cooler and bypass the one in the radiator....Oh there is no plug in the torque converter that would have to be removed for a 100% fluid replacement...But I think that is really unnecessary!
Old 01-15-2010, 04:39 AM
Chapter Director
Thanks everyone for their help and advice. I think that I will find someone who will drop the pan and replace the filter along with the fluid change.
Old 01-20-2010, 05:52 AM
the more important filter to change it the bypass filter on the frame. I don't know why but the dealers seem pretty "dumb" when you ask them about it. When I asked what the dealer near me charged to do the flush they said $189. I aksed if that included filter and they said it didn't need to be changed. True for the in pan filter, but not for the frame mounted filter, thats every 30K. and when I changed mine it was pretty dirty
Old 01-20-2010, 09:17 PM
cubalz, you said southeast diesel. Where is that???
