Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Trannie problems
Old 03-29-2007, 10:52 AM
Rescuediver Rescuediver is offline
SMOKE ROLLER
Poping on the Floorboard?!?
Okay, Now I need a little help... I have noticed a popping in the floorboard under "WOT".. I feels like the tranny is puking on the underside of the floorboard.. She shift perfect and there is no problems shifting through the gears up or down.. It's and Automatic and I noticed no other problems other than every now and then I hear this poping and feels like someone is trapped under the truck and beating on the floorboard under my feet.. Any thoughts.....................
Old 03-29-2007, 10:58 AM
Dave Dave is online now
Obama sucks
mine was sway bar end link bushings goin bad when that happened but dont know if your 05 had those
Old 03-29-2007, 11:08 AM
dustindiesel dustindiesel is offline
could it be the carrier bearing for the driveshaft???
Obama sucks
Also a very good possibility
Old 03-29-2007, 12:32 PM
SMOKE ROLLER
That would be with a two piece driveshaft right?? I'm going to check it now...
Old 03-29-2007, 12:54 PM
SMOKE ROLLER
Okay guys I found it, but not sure how to tell if it is bad. Is it cheap and easy enough to just replace it anyway??
Old 03-29-2007, 01:54 PM
nsrchofpwr nsrchofpwr is offline
lifetime member
does it appear to be bad? how much play is in it?
Old 03-29-2007, 01:55 PM
xtremexj xtremexj is offline
I've got a suspicion that mine has this problem - but only on the passenger side.
Old 03-29-2007, 01:59 PM
SMOKE ROLLER
It has a rubber spacer that seems okay, but I can't seem to see any play in the bearing. Again I'm really not sure what I'm looking at or for...
Old 03-29-2007, 02:04 PM
lifetime member
you should be able to move the driveshaft around a little bit. at least a 1/4 inch . it should be tight in the rubber, but the rubber has some give to it the way it is made.
